Component: Digital Potentiometer (MCP41XX / MCP42XX) (Analog Output)
Revision as of 21:08, 16 November 2021 by Wiki bot (talk | contribs)
Category Analog Output
Digital Potentiometer (MCP41XX / MCP42XX) component
The MCP41XX and MCP42XX device range supports up to 2 digital potentiometers or rheostat outputs. 129 or 257 possible output resistance values for each channel.
Fc9-comp-macro.png IncrementWiper
Increments a single volatile wiper value
Fc9-u8-icon.png - BYTE Index
Range: 0-3
Fc9-comp-macro.png DecrementWiper
Decrements a single volatile wiper value
Range: 0-1
Fc9-comp-macro.png SetWiper
Sets the value of a single wiper
Range: 0-3
Fc9-u16-icon.png - UINT Value
129 Taps Range: 0-128 / 257 Taps Range: 0-256
[[File:]] - MemoryType
0=Volatile, 1=Nonvolatile
Fc9-comp-macro.png ReadAddress
Reads a value from one of the registers on the device
Range: 0-15
Fc9-comp-macro.png WriteAddress
Writes a value to one of the registers on the device
Range: 0-15
Range: 0-256
Fc9-comp-macro.png Initialise
Startup the SPI peripheral ready for communications.
Starts up the I2C comms ready for communicating with the LP503x module. Must be called before any of the other component macros are called.
Fc9-comp-macro.png Refresh
Clocks out the current colour data to the LEDs from the values stored in RAM
Fc9-comp-macro.png ShiftLEDs1D
Shifts the LED colours in 1D and wraps
Fc9-u8-icon.png - BYTE Direction
0 = Forwards, 1 = Backwards
Fc9-u8-icon.png - BYTE DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
Fc9-comp-macro.png DrawLine3D
Draws a line on a 3D array of LEDs
Fc9-u16-icon.png - UINT X1
Start X Coordinate
Fc9-u16-icon.png - UINT Y1
Start Y Coordinate
Fc9-u16-icon.png - UINT Z1
Start Z Coordinate
Fc9-u16-icon.png - UINT X2
End X Coordinate
Fc9-u16-icon.png - UINT Y2
End Y Coordinate
Fc9-u16-icon.png - UINT Z2
End Z Coordinate
Fc9-u8-icon.png - BYTE R
Red Colour Channel
Fc9-u8-icon.png - BYTE G
Green Colour Channel
Fc9-u8-icon.png - BYTE B
Blue Colour Channel
Fc9-comp-macro.png Delay_T1H
Fc9-comp-macro.png GetLEDIndex2D
Sets the index of a single LED in RAM as a 2D array.
LED Column to change the colour / Range: 0 to (LED Column - 1)
LED Row to change the colour / Range: 0 to (LED Row - 1)
Fc9-comp-macro.png DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
Fc9-u8-icon.png - BYTE X1
Fc9-u8-icon.png - BYTE Y1
Fc9-u8-icon.png - BYTE X2
Fc9-u8-icon.png - BYTE Y2
Fc9-u8-icon.png - BYTE DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
Fc9-comp-macro.png ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
[[File:]] - X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
[[File:]] - Y
Fc9-comp-macro.png GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
Fc9-comp-macro.png DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
Start X pixel coordinate
Start Y pixel coordinate
Fc9-u8-icon.png - BYTE Z1
Start Z pixel coordinate
End X pixel coordinate
End Y pixel coordinate
Fc9-u8-icon.png - BYTE Z2
End Z pixel coordinate
Red Colour Channel
White Colour Channel
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the LED ICs in the chain.
Fc9-comp-macro.png ShiftLEDs3D
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
Sets up the data memory and draws the simulated LED cube on the panel.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-16-icon.png MOSI Remap Pin
Fc9-type-5-icon.png MISO
Fc9-type-16-icon.png MISO Remap Pin
Fc9-type-5-icon.png CLK
Fc9-type-16-icon.png CLK Remap Pin
Fc9-type-5-icon.png CS / SS
Fc9-type-16-icon.png Number of Outputs
Fc9-type-16-icon.png Number of Taps
Fc9-type-16-icon.png API
Fc9-conn-icon.png Simulations
