Component: Column Chart (Charts)
Revision as of 10:34, 17 November 2021 by Wiki bot (talk | contribs)
Author Steve Tandy
Version 1.1
Category Charts
Column Chart component
A 2d column chart component.
Fc9-comp-macro.png Clear
Resets the XY chart and removes all data points.
Fc9-comp-macro.png AddPoint
Add a point to the selected data series.
Fc9-string-icon.png - STRING Category
The name of the category for the data point
[[File:]] - Y
The Y coordinate of the data point
Fc9-u8-icon.png - BYTE Index
The data series (1-8)
Fc9-comp-macro.png SetValue
Sets the component to the specified value.
[[File:]] - value
A new value for the component.
Fc9-comp-macro.png RefreshChart
Redraws the chart.
Fc9-comp-macro.png GetData
Gets a data point from the specified series.
Fc9-u8-icon.png - BYTE Series
Which series to add to (1-8)
[[File:]] - Index
The data point index (1 - 32767)
[[File:]] - Return
Fc9-comp-macro.png AddDataCXYY1
Adds a data point to a bubble chart.
[[File:]] - Y
Y coordinate
[[File:]] - X
X coordinate
[[File:]] - Value
The value of the data point
Fc9-comp-macro.png GetList
Returns CHANNEL or PRESCALE list from the FCD and updates the internal property
Fc9-string-icon.png - STRING Name
Fc9-comp-macro.png InitRXConfig
Initialization setting for RX Buffer Config
Fc9-u8-icon.png - BYTE Buffer
Buffer Number (0 or 1)
Fc9-u8-icon.png - BYTE Value
Config data byte
Fc9-comp-macro.png Uninit
Uninitialises the CAN, freeing its connections for general use
Get the Filter List of the Named Property
Fc9-comp-macro.png GetRxIdent
Generic function to get the received message Identifier.
Fc9-u8-icon.png - BYTE buffer
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png SetRxFilterStd
Sets the 16-bit filter as a bit-mask of the standard ID for received messages The messages are accepted if (StdID & Mask) == Filter
Fc9-u8-icon.png - BYTE Filter
Filter number
Fc9-u8-icon.png - BYTE Hi
The high byte (bits 8-15) of the ID
Fc9-u8-icon.png - BYTE Lo
The low byte (bits 0-7) of the ID
Fc9-comp-macro.png SetRxFilterExd
Sets the 32-bit filter as a bit-mask of the extended ID for received messages The messages are accepted if (ExtID & Mask) == Filter
Send filter: 0 to 3
Fc9-u8-icon.png - BYTE ID3
The high byte (bits 24-31) of the ID
Fc9-u8-icon.png - BYTE ID2
The mid-high byte (bits 16-23) of the ID
Fc9-u8-icon.png - BYTE ID1
The mid-low byte (bits 8-15) of the ID
Fc9-u8-icon.png - BYTE ID0
Fc9-type-11-icon.png Categories
Fc9-type-11-icon.png Y Values
Fc9-type-10-icon.png Title
Fc9-type-12-icon.png Style
Fc9-type-12-icon.png Stacking
Fc9-type-12-icon.png Fill Gradient
Fc9-type-10-icon.png Name
Fc9-type-7-icon.png Show Grid
Fc9-type-7-icon.png Auto-scale
Fc9-type-15-icon.png Start
Fc9-type-15-icon.png End
Fc9-type-7-icon.png Logarithmic
Fc9-type-7-icon.png Show Category
Fc9-type-7-icon.png Show Value
Fc9-type-7-icon.png Show Series
Fc9-type-12-icon.png Position
Fc9-type-7-icon.png Draw Border
Fc9-type-16-icon.png Select Series
Fc9-type-10-icon.png Series Name
Fc9-type-7-icon.png Visible
Fc9-conn-icon.png Simulations
