Component: DSPBufferRef (DSP)
Revision as of 10:35, 17 November 2021 by Wiki bot (talk | contribs)
Category DSP
DSPBufferRef component
Reference and access to a specific DSP buffer inside another DSP component. Used for a DSP component input buffer.
Fc9-comp-macro.png Prv_PutPropStr
Fc9-u16-icon.png - UINT Idx
Fc9-u16-icon.png - UINT Val
Fc9-comp-macro.png Prv_PutConsole
Fc9-u32-icon.png - ULONG Val
Fc9-comp-macro.png get
[[File:]] - Return
Fc9-comp-macro.png put
[[File:]] - Val
Fc9-comp-macro.png Prv_GetPropStr
Fc9-comp-macro.png Prv_GetConsole
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png SetHandle
[[File:]] - Handle
Fc9-comp-macro.png Uninit
Un-initialize the UART and release the resources
Fc9-comp-macro.png ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
Fc9-u8-icon.png - BYTE Data
A byte array variable to hold the received data
Fc9-u16-icon.png - UINT NumBytes
Maximum number of bytes to try and receive
Fc9-u16-icon.png - UINT Timeout
Max amount of time in ms to wait between bytes
Fc9-comp-macro.png ReceiveString
Receives a string of bytes and returns the number of bytes received.
Fc9-string-icon.png - STRING StringData
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Fc9-comp-macro.png SetLEDState
Sets the state of a single LED
Fc9-u8-icon.png - BYTE Port
0 = PortA, 1 = PortB
Fc9-u8-icon.png - BYTE LED
0 = LED0, 7 = LED7
Fc9-u8-icon.png - BYTE State
Fc9-comp-macro.png GetRxIdent
Gets the Rx ID as a Integer Standard and Extended IDs.
Fc9-u8-icon.png - BYTE Buffer
Fc9-comp-macro.png Initialise
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
Fc9-type-17-icon.png Link To
Fc9-type-10-icon.png Subname
Fc9-type-21-icon.png Subhandle
Fc9-type-21-icon.png Buffer Type
Fc9-type-21-icon.png Console Handle
Fc9-type-2-icon.png Color
Fc9-type-2-icon.png Outline
Fc9-type-10-icon.png Text
Fc9-type-16-icon.png Orientation
Fc9-conn-icon.png Simulations
