Component: Output DAC (DSP)
Revision as of 10:35, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category DSP
Output DAC component
Allows the values from a buffer to be passed directly to an internal DAC output.
Fc9-comp-macro.png OutputDACArray
Outputs an array of values from the input buffer appropriatley scaled to suit the DAC.
Fc9-u16-icon.png - UINT Delay
Delay in microseconds between outputting each sample.
Fc9-comp-macro.png ControlDAC
Enable or disable the DAC output, Disabled by default.
[[File:]] - State
Outputs a single value from the input buffer appropriatley scaled to suit the DAC.
Fc9-comp-macro.png Prv_GetConsole
Fc9-u16-icon.png - UINT Idx
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png SetHandle
[[File:]] - Handle
Fc9-comp-macro.png Uninit
Un-initialize the UART and release the resources
Fc9-comp-macro.png ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
Fc9-u8-icon.png - BYTE Data
A byte array variable to hold the received data
Fc9-u16-icon.png - UINT NumBytes
Maximum number of bytes to try and receive
Fc9-u16-icon.png - UINT Timeout
Max amount of time in ms to wait between bytes
Fc9-comp-macro.png ReceiveString
Receives a string of bytes and returns the number of bytes received.
Fc9-string-icon.png - STRING StringData
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Fc9-comp-macro.png SetLEDState
Sets the state of a single LED
Fc9-u8-icon.png - BYTE Port
0 = PortA, 1 = PortB
Fc9-u8-icon.png - BYTE LED
0 = LED0, 7 = LED7
Fc9-u8-icon.png - BYTE State
Fc9-comp-macro.png GetRxIdent
Gets the Rx ID as a Integer Standard and Extended IDs.
Fc9-u8-icon.png - BYTE Buffer
Fc9-comp-macro.png Initialise
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
Fc9-type-17-icon.png Connect To
Fc9-type-16-icon.png Channel
DAC Channel number
Fc9-type-5-icon.png DAC Output Pin
DAC Output Pin
Fc9-type-16-icon.png Vref Option
Fc9-type-15-icon.png Vref Voltage
Fc9-type-14-icon.png Control Bits
Fc9-type-10-icon.png Resolution
Fc9-type-15-icon.png Voltage Resolution
Fc9-conn-icon.png Simulations
