Component: Deinterlace (DSP)
Revision as of 10:35, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category DSP
Deinterlace component
Allows multiple output buffers to be deinterlaced from a single input buffer. Useful for decoding multiple buffer channels sent via communications or storage.
Fc9-comp-macro.png DeinterlaceArray
Repeats the deinterlace function as many times as set in the data count property.
Outputs a single value to each of the connected output buffers from the input buffer.
Fc9-comp-macro.png SetHandle
[[File:]] - Handle
Fc9-comp-macro.png Uninit
Un-initialize the UART and release the resources
Fc9-comp-macro.png ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
Fc9-u8-icon.png - BYTE Data
A byte array variable to hold the received data
Fc9-u16-icon.png - UINT NumBytes
Maximum number of bytes to try and receive
Fc9-u16-icon.png - UINT Timeout
Max amount of time in ms to wait between bytes
Fc9-comp-macro.png ReceiveString
Receives a string of bytes and returns the number of bytes received.
Fc9-string-icon.png - STRING StringData
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Fc9-comp-macro.png SetLEDState
Sets the state of a single LED
Fc9-u8-icon.png - BYTE Port
0 = PortA, 1 = PortB
Fc9-u8-icon.png - BYTE LED
0 = LED0, 7 = LED7
Fc9-u8-icon.png - BYTE State
Fc9-comp-macro.png GetRxIdent
Gets the Rx ID as a Integer Standard and Extended IDs.
Fc9-u8-icon.png - BYTE Buffer
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png Initialise
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
Fc9-type-17-icon.png Connect To
Fc9-type-21-icon.png Buffer Size 0
Fc9-type-16-icon.png Buffer Type 0
Fc9-type-21-icon.png Buffer Size 1
Fc9-type-16-icon.png Buffer Type 1
Fc9-type-21-icon.png Buffer Size 2
Fc9-type-16-icon.png Buffer Type 2
Fc9-type-21-icon.png Buffer Size 3
Fc9-type-16-icon.png Buffer Type 3
Fc9-type-21-icon.png Buffer Size 4
Fc9-type-16-icon.png Buffer Type 4
Fc9-type-21-icon.png Buffer Size 5
Fc9-type-16-icon.png Buffer Type 5
Fc9-type-16-icon.png Number of Outputs
The number of inputs the multiplexer can switch between.
Fc9-type-21-icon.png Data Count
Number of complete output packets the buffer can store. Default 1.
Fc9-type-16-icon.png Input Mode
Fc9-conn-icon.png Simulations
