Component: Input CSV (DSP)
Revision as of 10:35, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category DSP
Input CSV component
Allows the values from a buffer to be collected directly from a CSV file. Either a value at a time or from an array.
Fc9-comp-macro.png ReadArray
Reads an array of values to fill up the specified buffer. Auto increments current location. FAT component must be initialised before calling this macro.
Fc9-comp-macro.png ReadValue
Reads a single value from the current position in the CSV file. Then auto increments the position. FAT component must be initialised before calling this macro.
Fc9-comp-macro.png QueueData
Takes a single value from the buffer input and stores it, once there are enough values queued up it returns a 1.
[[File:]] - ProcessWhenFull
0 = Do Nothing when Buffer is full, 1 = Auto call FFT macro when Buffer is full
[[File:]] - Return
Fc9-comp-macro.png Uninit
Un-initialize the UART and release the resources
Fc9-comp-macro.png ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
Fc9-u8-icon.png - BYTE Data
A byte array variable to hold the received data
Fc9-u16-icon.png - UINT NumBytes
Maximum number of bytes to try and receive
Fc9-u16-icon.png - UINT Timeout
Max amount of time in ms to wait between bytes
Fc9-comp-macro.png ReceiveString
Receives a string of bytes and returns the number of bytes received.
Fc9-string-icon.png - STRING StringData
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Fc9-comp-macro.png SetLEDState
Sets the state of a single LED
Fc9-u8-icon.png - BYTE Port
0 = PortA, 1 = PortB
Fc9-u8-icon.png - BYTE LED
0 = LED0, 7 = LED7
Fc9-u8-icon.png - BYTE State
Fc9-comp-macro.png GetRxIdent
Gets the Rx ID as a Integer Standard and Extended IDs.
Fc9-u8-icon.png - BYTE Buffer
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png Initialise
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type, data is automatically scaled to fit and make full use of the data type.
Fc9-type-17-icon.png FAT Component
Points to the FAT filesystem component to allow access to file system and embedded SD card.
Fc9-type-10-icon.png Filename
Name of the file to read DSP data from.
Fc9-type-16-icon.png Layout
Dictates if the data is read from a single column or a single row.
Fc9-conn-icon.png Simulations
