Component: Output CSV (DSP)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | DSP |
Output CSV component
Allows the values from a buffer to be output directly into a .CSV format file. Either a value at a time or as an array.
WriteArray |
Writes a buffer of values from the selected DSP buffer to the CSV file. FAT component must be initialised before calling this macro. | |
Return |
WriteValue |
Writes a single value from the selected DSP buffer to the CSV file. FAT component must be initialised before calling this macro. | |
Return |
Uninit |
Un-initialize the UART and release the resources | |
Return |
Start |
Startup routine required by the hardware device. Automatically clears the display after initialising. | |
Return |
SetLEDState |
Sets the state of a single LED | |
Port |
0 = PortA, 1 = PortB | |
LED |
0 = LED0, 7 = LED7 | |
State |
Return |
GetRxIdent |
Gets the Rx ID as a Integer Standard and Extended IDs. | |
Buffer |
Return |
Initialise |
Must be called before any other CAN component macros to enable and initialise the CAN peripheral. | |
Return |
