Component: Input Digital (DSP)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | DSP |
Input Digital component
Allows the values from a buffer to be assigned. Either a value at a time or from an array. The input signal would usually take the form of an ADC reading or raw data values.
Here is a basic example demonstrating how to pass a value into the DSP chain.
Delay
The input value in the example uses an ADC reading but this can be taken from anything such as a reading from a CSV file on a SD card or a value passed by a sensor on a I2C bus etc.
AddByte |
Adds a single byte value to the current location in the specified buffer and scales it appropriatley to suit the buffer. Auto increments current location. | |
Data |
Return |
AddByteArray |
Adds an array of byte values to the specified buffer and scales it appropriatley to suit the buffer. Auto increments current location. | |
Data |
Count |
Return |
AddLong |
Adds a single unsigned long value to the current location in the specified buffer and scales it appropriatley to suit the buffer. Auto increments current location. | |
Data |
Return |
AddInt |
Adds a single unsigned int value to the current location in the specified buffer and scales it appropriatley to suit the buffer. Auto increments current location. | |
Data |
Return |
AddLongArray |
Adds an array of long values to the specified buffer and scales it appropriatley to suit the buffer. Auto increments current location. | |
Data |
Count |
Return |
AddIntArray |
Adds an array of integer values to the specified buffer and scales it appropriatley to suit the buffer. Auto increments current location. | |
Data |
Count |
Return |
CheckBuffer |
Returns the number of values in the transmit or receive buffer | |
[[File:]] - | Buffer |
0=Transmit / 1=Receive | |
Return |
ReceiveString |
Gets a string from the receive buffer | |
MaxChars |
Timeout |
Time in milliseconds to wait for data | |
Return |
Initialise |
Initialises the UART component pins ready to send and receive data | |
Return |
Start |
Startup routine required by the hardware device. Automatically clears the display after initialising. | |
Return |
SetLEDState |
Sets the state of a single LED | |
Port |
0 = PortA, 1 = PortB | |
LED |
0 = LED0, 7 = LED7 | |
State |
Return |
GetRxIdent |
Gets the Rx ID as a Integer Standard and Extended IDs. | |
Buffer |
Return |
Initialise |
Must be called before any other CAN component macros to enable and initialise the CAN peripheral. | |
Return |
