Component: Interlace (DSP)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | DSP |
Interlace component
Allows multiple input buffers to be interlaced together into a single output buffer. Useful for combining several streams together for sending out via communications or storing.
Interlace |
Collects a single value from each of the connected input buffers and places in order into the output buffer. | |
Return |
InterlaceArray |
Repeats the interlace function as many times as set in the data count property. | |
Return |
AddIntArray |
Adds an array of integer values to the specified buffer and scales it appropriatley to suit the buffer. Auto increments current location. | |
Data |
Count |
Return |
CheckBuffer |
Returns the number of values in the transmit or receive buffer | |
[[File:]] - | Buffer |
0=Transmit / 1=Receive | |
Return |
ReceiveString |
Gets a string from the receive buffer | |
MaxChars |
Timeout |
Time in milliseconds to wait for data | |
Return |
Initialise |
Initialises the UART component pins ready to send and receive data | |
Return |
Start |
Startup routine required by the hardware device. Automatically clears the display after initialising. | |
Return |
SetLEDState |
Sets the state of a single LED | |
Port |
0 = PortA, 1 = PortB | |
LED |
0 = LED0, 7 = LED7 | |
State |
Return |
GetRxIdent |
Gets the Rx ID as a Integer Standard and Extended IDs. | |
Buffer |
Return |
Initialise |
Must be called before any other CAN component macros to enable and initialise the CAN peripheral. | |
Return |
