Component: Math (DSP)
Revision as of 10:35, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category DSP
Math component
Component to combine together two DSP buffers into one an index at a time. Functions include: Add, Average, Difference, Max, Min, Subtract
Here is a example file which generates a sine wave and a triangle wave and then uses the DSP sum component to merge together the two signals. FC6 Icon.png DSPSum Here is the kind of waveform you can expect to see using the scope window when adding the two signals together.
Here is the kind of waveform you can expect to see using the scope window when subtracting the two readings.
Here is the kind of waveform you can expect to see using the scope window when taking the maximum of the two signals.
Here is the kind of waveform you can expect to see using the scope window when taking the minimum of the two signals.
Here is the kind of waveform you can expect to see using the scope window when taking the average between the two signals.
Here is the kind of waveform you can expect to see using the scope window when taking the difference between the two signals.
Fc9-comp-macro.png Calculate
Performs a single calculation on the two input buffers and provides a result into the output buffer
Fc9-comp-macro.png CalculateArray
Fc9-comp-macro.png ReadPeakArray
Returns the highest value from the last "Decay" number of buffers.
Fc9-comp-macro.png ReadAverageArray
Returns the average from the last "Decay" number of buffers.
Returns the highest value from the last "Decay" number of index locations.
[[File:]] - Return
Fc9-comp-macro.png ResetRecords
Allows the peak and trough to be reset back to default values.
[[File:]] - ResetPeak
[[File:]] - ResetTrough
Fc9-comp-macro.png ReceiveString
Gets a string from the receive buffer
Fc9-u16-icon.png - UINT MaxChars
Fc9-u16-icon.png - UINT Timeout
Time in milliseconds to wait for data
Fc9-comp-macro.png Initialise
Initialises the UART component pins ready to send and receive data
Receives a string of bytes and returns the number of bytes received.
Fc9-string-icon.png - STRING StringData
Fc9-u16-icon.png - UINT NumBytes
Maximum number of bytes to try and receive
Max amount of time in ms to wait between bytes
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Fc9-comp-macro.png SetLEDState
Sets the state of a single LED
Fc9-u8-icon.png - BYTE Port
0 = PortA, 1 = PortB
Fc9-u8-icon.png - BYTE LED
0 = LED0, 7 = LED7
Fc9-u8-icon.png - BYTE State
Fc9-comp-macro.png GetRxIdent
Gets the Rx ID as a Integer Standard and Extended IDs.
Fc9-u8-icon.png - BYTE Buffer
Fc9-u32-icon.png - ULONG Return
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
Fc9-type-17-icon.png Connect To A
DSP component with output buffer to collect our A data from.
Fc9-type-17-icon.png Connect To B
DSP component with output buffer to collect our B data from.
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type.
Fc9-type-16-icon.png Sum Type
Defines the type of calculation performed on the two input buffers to obtain the output value. Data shown in brackets indicates operation ? = a decision followed by the true value and then the false value seperated with a colon.
Fc9-conn-icon.png Simulations
