Component: Device Helper (Matrix Tools)
Revision as of 10:35, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.1
Category Matrix Tools
Device Helper component
A purely cosmetic component for viewing the details specific to your current selected target microcontroller. Lists stats like ADC resolution, ADC channels, UARTs, SPI, PWM, RAM, ROM etc
By simply adding the device helper component to your project and selecting it on the panel you can see all the following statistics regarding your current selected microcontroller in the properties window.
Fc9-comp-macro.png ResetRecords
Allows the peak and trough to be reset back to default values.
[[File:]] - ResetPeak
[[File:]] - ResetTrough
Fc9-comp-macro.png ReceiveString
Gets a string from the receive buffer
Fc9-u16-icon.png - UINT MaxChars
Fc9-u16-icon.png - UINT Timeout
Time in milliseconds to wait for data
Fc9-comp-macro.png Initialise
Initialises the UART component pins ready to send and receive data
Receives a string of bytes and returns the number of bytes received.
Fc9-string-icon.png - STRING StringData
Fc9-u16-icon.png - UINT NumBytes
Maximum number of bytes to try and receive
Max amount of time in ms to wait between bytes
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Fc9-comp-macro.png SetLEDState
Sets the state of a single LED
Fc9-u8-icon.png - BYTE Port
0 = PortA, 1 = PortB
Fc9-u8-icon.png - BYTE LED
0 = LED0, 7 = LED7
Fc9-u8-icon.png - BYTE State
Fc9-comp-macro.png GetRxIdent
Gets the Rx ID as a Integer Standard and Extended IDs.
Fc9-u8-icon.png - BYTE Buffer
Fc9-u32-icon.png - ULONG Return
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
Fc9-type-21-icon.png Pin Count
Fc9-type-21-icon.png Max Clock Speed
Maximum frequency the device can operate.
Fc9-type-21-icon.png Master Divider
Number of clock cycles per single device instruction.
Fc9-type-21-icon.png Max MIPs
Million Instructions Per Second (MIPS) Number of complete instruction cycles per second based on the max clock speed and instructions per clock divided by 1 million. Note that some instructions such as decisions can take multiple instructions to complete.
Fc9-type-21-icon.png ROM Size
Number of bytes available for ROM storage. ROM - Read Only Memory - Contains the Flowcode program as well as other constants such as strings
Fc9-type-21-icon.png RAM Size
Number of bytes available for RAM storage. RAM - Random Access Memory - Contains the Flowcode variables as well as the operational stack
Fc9-type-21-icon.png EEPROM Size
Number of bytes available for EEPROM storage. EEPROM - Electrically Erasable Programmable Read Only Memory - Contains user data that can persist when the power is removed
Fc9-type-21-icon.png ADC Max Bits
Maximum number of bits used for an ADC conversion which dictates the maximum reading the ADC can generate. 8 bits = 0 - 255 10 bits = 0 - 1023 12 bits = 0 - 4095
Fc9-type-21-icon.png ADC Pins
Number of pins capable of reading an analogue input.
Fc9-type-21-icon.png DAC Max Bits
Maximum number of bits used for an DAC conversion which dictates the output resolution of the DAC. 5 bits = 0 - 31 8 bits = 0 - 255 10 bits = 0 - 1023
Fc9-type-21-icon.png DAC Pins
Number of pins capable of outputting an analogue voltage.
Fc9-type-21-icon.png Digital Pins
Number of pins capable of reading a digital input and/or writing a digital output.
Fc9-type-21-icon.png CAN Count
Controller Area Network (CAN) Used for fixed system architecture in noisy environments e.g. Cars and Automotive
Fc9-type-21-icon.png I2C Count
Inter-Integrated Circuit (I2C) Used for on board communications e.g. Sensors, Memory
Fc9-type-10-icon.png I2C Modes
Fc9-type-21-icon.png H-Bridge Count
Fc9-type-21-icon.png PWM Count
Pulse Width Modulation Output (PWM) Useful for analogue style outputs.
Fc9-type-21-icon.png SPI Count
Serial Peripheral Interface (SPI) Used for high speed on board communications e.g. Sensors, Memory
Fc9-type-21-icon.png UART Count
Universal Asynchronous Receiver Transmitter (UART) Used for on board and off board communications e.g. RS232, Bluetooth, GPS, GSM
Fc9-type-21-icon.png USB Count
Universal Serial Bus (USB) Used for interconnective communications with high end equipment such as PCs.
Fc9-conn-icon.png Simulations
