Component: Offset (DSP)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.1 |
Category | DSP |
Offset component
Allows the values in a single buffer to be offset uniformly. Functions include: Add, Subtract
Calculate |
Performs the selected offset on a value from the input buffer and passes to the output buffer. | |
Return |
CalculateArray |
Performs the selected offset on an entire buffer. | |
Return |
SetOffset |
Sets the Offset to be used when calling the calculate function. | |
[[File:]] - | Offset |
Return |
ResetRecords |
Allows the peak and trough to be reset back to default values. | |
[[File:]] - | ResetPeak |
[[File:]] - | ResetTrough |
Return |
ReceiveString |
Gets a string from the receive buffer | |
MaxChars |
Timeout |
Time in milliseconds to wait for data | |
Return |
Initialise |
Initialises the UART component pins ready to send and receive data | |
Return |
Start |
Startup routine required by the hardware device. Automatically clears the display after initialising. | |
Return |
SetLEDState |
Sets the state of a single LED | |
Port |
0 = PortA, 1 = PortB | |
LED |
0 = LED0, 7 = LED7 | |
State |
Return |
GetRxIdent |
Gets the Rx ID as a Integer Standard and Extended IDs. | |
Buffer |
Return |
Initialise |
Must be called before any other CAN component macros to enable and initialise the CAN peripheral. | |
Return |
