Component: E block Helper (E blocks 1)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.1 |
Category | E-blocks 1 |
E-block Helper component
A purely cosmetic component to help simplify E-block connections without having to keep referring to the datasheets. Specify which E-block your using and the component will give you options for the patch settings and display the connections required.
Example of E-blocks helper component being used to determine connections.
ReceiveCount |
Returns the number of bytes currently sat waiting in the receive buffer. | |
Return |
ReadString |
Copies the incoming data from the data string array to a local string variable. | |
NumBytes |
Maximum number of bytes to try and read | |
Return |
SendByte |
Sends a single data byte out to the Bluetooth module. | |
Data |
Return |
EnterCommandMode |
Enters command mode allowing commands to be sent using the SendCommand macro. Returns: 0 = No Reply / 1 = Command Mode OK | |
[[File:]] - | Return |
GetMACAddress |
Gets the local Bluetooth device MAC address. | |
Return |
Initialise |
Sets up the Bluetooth module including: - Enabling the UART - Configuring the module (Name / Key / etc) Returns 1 for OK and 0 for no reply. | |
Return |
Start |
Startup routine required by the hardware device. Automatically clears the display after initialising. | |
Return |
SetLEDState |
Sets the state of a single LED | |
Port |
0 = PortA, 1 = PortB | |
LED |
0 = LED0, 7 = LED7 | |
State |
Return |
GetRxIdent |
Gets the Rx ID as a Integer Standard and Extended IDs. | |
Buffer |
Return |
Initialise |
Must be called before any other CAN component macros to enable and initialise the CAN peripheral. | |
Return |
