Component: Relay (Grove 103020005) (103020005) (General Output)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | General Output |
Relay (Grove 103020005) component
The Relay is a digital normally open switch capable of switching much higher voltages and currents than your normal Microcontroller outputs. When set to HIGH, the LED will light up and the relay will close allowing current to flow. The peak voltage capability is 250V at 10 amps. Simulated component, green indiacator is on when the relay is active.
SwitchOn |
Switch on the relay, connecting the common pin to the normally open pin. | |
Return |
SwitchOff |
Switch off the relay, disconnecting the common pin from the normally open pin. | |
Return |
GetAverageInt |
Function call to read the ADC as a full width average sample over time | |
NumSamples |
DelayUs |
Number of micro seconds in between taking each sample | |
Return |
GetVoltage |
Reads the ADC as a direct voltage | |
[[File:]] - | Return |
GetInt |
Blocking call to read the ADC at full bit depth | |
Return |
GetByte |
Blocking call to read the ADC as a byte | |
Return |
Initialise |
Initialise the sensor configuration as set by the component properties. Sets the default intigration time and gain as well as enable the sensor. | |
Return |
Initialise |
Starts up the I2C bus and initialises the pressure sensor ready for use. Returns 1 for a sucessful startup. Returns 0 for a failed startup or no device detected. | |
Return |
Initialise |
Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail. | |
Return |
SampleAccel |
Samples the accelerometer 0 = no new data, 1 = new data available | |
Return |
Left |
Rotates the robot left - waits for the angle to be traversed before returning | |
Angle |
Angle to turn in degrees | |
Return |
LCDDrawPixel |
Allows a single pixel on the LCD to be set or cleared | |
X |
X Pixel 0-127 | |
Y |
Y Pixel 0-31 | |
State |
0=White (Off), 1=Black (On) | |
Return |
ServoSetPosition |
Allows one of the servo positions to be assigned | |
Channel |
Range 0-3 | |
Position |
Range 0-255 | |
Return |
CardBitmap |
Displays a monochrome bitmap read from the card on the LCD | |
X |
Range 0-127 | |
Y |
Range 0-31 | |
Filename |
Return |
CardOpen |
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK | |
Filename |
Return |
Forwards |
Drives the robot forwards - waits for the distance to be traversed before returning | |
Distance |
Distance in mm | |
Return |
ReadBearing |
Reads the compass bearing based on the degrees clockwise from magnetic north. | |
GetConsoleHandle |
Gets the handle to the console allowing data displaying on the panel etc. | |
LCDDrawLine |
Allows a single pixel width line to be drawn on the LCD | |
X1 |
X Pixel 0-127 | |
Y1 |
Y Pixel 0-31 | |
X2 |
X Pixel 0-127 | |
Y2 |
Y Pixel 0-31 | |
Return |
ServoAutoMoveToPosition |
Allows one of the servo positions to move gradually to a new position | |
Channel |
Range 0-3 | |
Position |
Range 0-255 | |
Return |
ReadAllValue |
Reads a single value stored from the read all command Index dictates which sensor value to read | |
Index |
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel | |
Return |
LCDBacklight |
Allows the LCD backlight brighntess to be adjusted | |
Intensity |
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness | |
Return |
LCDDrawRect |
Allows a rectangle to be drawn on the LCD | |
X1 |
X Pixel 0-127 | |
Y1 |
Y Pixel 0-31 | |
X2 |
X Pixel 0-127 | |
Y2 |
Y Pixel 0-31 | |
Return |
ReadLine |
Reads one of the IR line sensors 0-1 0=Left, 1=Right | |
index |
0=Left, 1=Right | |
Return |
ServoDisable |
Allows one of the servo outputs 0-3 to be disabled | |
Channel |
Range 0-3 | |
Return |
ServoEnable |
Allows one of the servo outputs 0-3 to be enabled | |
Channel |
Range 0-3 | |
Return |
CardReadByte |
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end | |
Return |
CardErase |
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK | |
Filename |
Return |
CardWriteByte |
Appends a byte to the end of the currently open file | |
Data |
Return |
EncoderRead |
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit. | |
index |
0=Left, 1=Right | |
Return |
SetMotors |
Sets the motor speeds without feedback Range -100 to 100 | |
[[File:]] - | Left |
[[File:]] - | Right |
Return |
Backwards |
Drives the robot backwards - waits for the distance to be traversed before returning | |
Distance |
Distance in mm | |
Return |
EncoderReset |
Resets the motor encoder counters | |
Return |
LCDVerbose |
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on | |
State |
0=Off 1=On | |
Return |
SetProp |
Allows the COM port property to be set from a parent component. | |
PropName |
PropVal |
Return |
CardInit |
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK | |
Return |
GetProp |
Allows the property filter for the COM port list to be copied to a parent component. | |
PropName |
Return |
LCDClear |
Clears the LCD | |
Return |
Properties |
Control Pin |
Connections |
Simulations |
