Component: Sound Sensor (Grove 101020023) (101020023) (Audio)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.0 |
Category | Audio |
Sound Sensor (Grove 101020023) component
The Sound sensor module is a simple microphone. Based on the power amplifier LM386 and the electret microphone, it can be used to detect the sound strength of the environment.
GetString |
Reads the ADC as a direct voltage and returns as as tring | |
Return |
GetAverageByte |
Function call to read the ADC as a byte average sample over time | |
NumSamples |
DelayUs |
Number of micro seconds in between taking each sample | |
Return |
GetAverageInt |
Function call to read the ADC as a full width average sample over time | |
NumSamples |
DelayUs |
Return |
GetVoltage |
Reads the ADC as a direct voltage | |
[[File:]] - | Return |
GetInt |
Blocking call to read the ADC at full bit depth | |
Return |
GetByte |
Blocking call to read the ADC as a byte | |
Return |
GetInt |
Return |
GetByte |
Return |
Initialise |
Initialise the sensor configuration as set by the component properties. Sets the default intigration time and gain as well as enable the sensor. | |
Return |
Initialise |
Starts up the I2C bus and initialises the pressure sensor ready for use. Returns 1 for a sucessful startup. Returns 0 for a failed startup or no device detected. | |
Return |
Initialise |
Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail. | |
Return |
SampleAccel |
Samples the accelerometer 0 = no new data, 1 = new data available | |
Return |
Left |
Rotates the robot left - waits for the angle to be traversed before returning | |
Angle |
Angle to turn in degrees | |
Return |
LCDDrawPixel |
Allows a single pixel on the LCD to be set or cleared | |
X |
X Pixel 0-127 | |
Y |
Y Pixel 0-31 | |
State |
0=White (Off), 1=Black (On) | |
Return |
ServoSetPosition |
Allows one of the servo positions to be assigned | |
Channel |
Range 0-3 | |
Position |
Range 0-255 | |
Return |
CardBitmap |
Displays a monochrome bitmap read from the card on the LCD | |
X |
Range 0-127 | |
Y |
Range 0-31 | |
Filename |
Return |
CardOpen |
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK | |
Filename |
Return |
Forwards |
Drives the robot forwards - waits for the distance to be traversed before returning | |
Distance |
Distance in mm | |
Return |
ReadBearing |
Reads the compass bearing based on the degrees clockwise from magnetic north. | |
GetConsoleHandle |
Gets the handle to the console allowing data displaying on the panel etc. | |
LCDDrawLine |
Allows a single pixel width line to be drawn on the LCD | |
X1 |
X Pixel 0-127 | |
Y1 |
Y Pixel 0-31 | |
X2 |
X Pixel 0-127 | |
Y2 |
Y Pixel 0-31 | |
Return |
ServoAutoMoveToPosition |
Allows one of the servo positions to move gradually to a new position | |
Channel |
Range 0-3 | |
Position |
Range 0-255 | |
Return |
ReadAllValue |
Reads a single value stored from the read all command Index dictates which sensor value to read | |
Index |
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel | |
Return |
LCDBacklight |
Allows the LCD backlight brighntess to be adjusted | |
Intensity |
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness | |
Return |
LCDDrawRect |
Allows a rectangle to be drawn on the LCD | |
X1 |
X Pixel 0-127 | |
Y1 |
Y Pixel 0-31 | |
X2 |
X Pixel 0-127 | |
Y2 |
Y Pixel 0-31 | |
Return |
ReadLine |
Reads one of the IR line sensors 0-1 0=Left, 1=Right | |
index |
0=Left, 1=Right | |
Return |
ServoDisable |
Allows one of the servo outputs 0-3 to be disabled | |
Channel |
Range 0-3 | |
Return |
ServoEnable |
Allows one of the servo outputs 0-3 to be enabled | |
Channel |
Range 0-3 | |
Return |
CardReadByte |
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end | |
Return |
CardErase |
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK | |
Filename |
Return |
CardWriteByte |
Appends a byte to the end of the currently open file | |
Data |
Return |
EncoderRead |
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit. | |
index |
0=Left, 1=Right | |
Return |
SetMotors |
Sets the motor speeds without feedback Range -100 to 100 | |
[[File:]] - | Left |
[[File:]] - | Right |
Return |
Backwards |
Drives the robot backwards - waits for the distance to be traversed before returning | |
Distance |
Distance in mm | |
Return |
EncoderReset |
Resets the motor encoder counters | |
Return |
LCDVerbose |
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on | |
State |
0=Off 1=On | |
Return |
SetProp |
Allows the COM port property to be set from a parent component. | |
PropName |
PropVal |
Return |
CardInit |
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK | |
Return |
GetProp |
Allows the property filter for the COM port list to be copied to a parent component. | |
PropName |
Return |
LCDClear |
Clears the LCD | |
Return |
