Component: IoT Made Easy (Comms: IoT/Cloud)
Revision as of 10:36, 17 November 2021 by Wiki bot (talk | contribs)
Category Comms: IoT/Cloud
IoT Made Easy component
A component designed to simplify MQTT comms allowing for multiple data streams to be dealt with in a simple manner. Deals with translating values to and from the broker from topic strings into message IDs and numeric values. Works with lots of different MQTT brokers.
Fc9-comp-macro.png ErrorAsString
Fc9-u8-icon.png - BYTE Error
Fc9-comp-macro.png PublishString
Publishes data to the selected topic ID using a data string. Returns none zero if successful
Fc9-u8-icon.png - BYTE TopicID
The topic ID to publish data to
Data string to publish
Fc9-comp-macro.png GetTopicID
Compares the topic ID of the last received message with enabled IDs. Returns the topic ID received.
Fc9-comp-macro.png Connect
Connect to the MQTT Server. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected.
Fc9-comp-macro.png GetPayloadInteger
Get the Payload of the last received (Read) packet as a signed long value
[[File:]] - Return
Fc9-comp-macro.png LastError
Returns the last error
Fc9-comp-macro.png Read
Read incoming data. Returns non-zero if packet received. Use GetTopicID and GetPayloadXXX to read the contents.
Fc9-comp-macro.png Disconnect
Disconnects from the MQTT server and the network
Fc9-comp-macro.png PublishFloat
Publishes data to the selected topic ID using a floating point value. Returns none zero if successful
[[File:]] - Data
Data to publish
Fc9-comp-macro.png Ping
Ping packet is sent to the server and checks for a reply. If nothing is sent or received within the keep alive period then a ping is required to keep the connection to the server active. Returns non-zero value if successful
Fc9-comp-macro.png PublishInteger
Publishes data to the selected topic ID using a signed long integer value. Returns none zero if successful
[[File:]] - Data
Data to publish
Fc9-comp-macro.png GetPayloadFloat
Get the Payload of the last received (Read) packet as a floating point value
[[File:]] - Return
Fc9-comp-macro.png GetPayloadString
Get the Payload of the last received (Read) packet as a string value
Fc9-string-icon.png - STRING Payload
Fc9-u8-icon.png - BYTE Size
Fc9-comp-macro.png Initialise
Starts up the MQTT component - call this after initialising the NetworkComms component.
Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
Fc9-comp-macro.png Left
Rotates the robot left - waits for the angle to be traversed before returning
Fc9-u16-icon.png - UINT Angle
Angle to turn in degrees
Fc9-comp-macro.png ReadIR
Reads an IR sensor 0=Left, 1=FrontLeft, 2=Front, 3=FrontRight, 4=Right, 5=RearRight, 6=Rear, 7=RearLeft
Fc9-u8-icon.png - BYTE index
Fc9-comp-macro.png LCDDrawPixel
Allows a single pixel on the LCD to be set or cleared
Fc9-u8-icon.png - BYTE X
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y
Y Pixel 0-31
Fc9-u8-icon.png - BYTE State
0=White (Off), 1=Black (On)
Fc9-comp-macro.png ServoSetPosition
Allows one of the servo positions to be assigned
Range 0-3
Fc9-u8-icon.png - BYTE Position
Range 0-255
Fc9-comp-macro.png CardBitmap
Displays a monochrome bitmap read from the card on the LCD
Range 0-127
Range 0-31
Fc9-comp-macro.png CardRecordMic
Records an audio stream on the card from the microphone
Fc9-u8-icon.png - BYTE BitDepth
0=8-bit, 1=16-bit
Fc9-u8-icon.png - BYTE SampleRate
Sample Rate 0=8KHz, 1=16KHz
Fc9-u16-icon.png - UINT RecordTime
Time to record for in seconds, Range 0-65535
Fc9-comp-macro.png CardOpen
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK
Fc9-comp-macro.png Forwards
Drives the robot forwards - waits for the distance to be traversed before returning
Fc9-u16-icon.png - UINT Distance
Distance in mm
Fc9-comp-macro.png ReadBearing
Reads the compass bearing based on the degrees clockwise from magnetic north.
[[File:]] - Return
[[File:]] - Return
Fc9-comp-macro.png LCDDrawLine
Allows a single pixel width line to be drawn on the LCD
Fc9-u8-icon.png - BYTE X1
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y1
Y Pixel 0-31
Fc9-u8-icon.png - BYTE X2
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y2
Y Pixel 0-31
Fc9-comp-macro.png ServoAutoMoveToPosition
Allows one of the servo positions to move gradually to a new position
Range 0-3
Range 0-255
Fc9-comp-macro.png ReadAllValue
Reads a single value stored from the read all command Index dictates which sensor value to read
Fc9-u8-icon.png - BYTE Index
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel
Fc9-comp-macro.png LCDBacklight
Allows the LCD backlight brighntess to be adjusted
Fc9-u8-icon.png - BYTE Intensity
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
Fc9-comp-macro.png LCDDrawRect
Allows a rectangle to be drawn on the LCD
X Pixel 0-127
Y Pixel 0-31
X Pixel 0-127
Y Pixel 0-31
Fc9-comp-macro.png ReadLine
Reads one of the IR line sensors 0-1 0=Left, 1=Right
0=Left, 1=Right
Fc9-comp-macro.png ServoDisable
Allows one of the servo outputs 0-3 to be disabled
Range 0-3
Fc9-comp-macro.png ServoEnable
Allows one of the servo outputs 0-3 to be enabled
Range 0-3
Fc9-comp-macro.png CardReadByte
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end
Fc9-comp-macro.png CardErase
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK
Fc9-comp-macro.png CardWriteByte
Appends a byte to the end of the currently open file
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png EncoderRead
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit.
0=Left, 1=Right
Fc9-comp-macro.png SetMotors
Sets the motor speeds without feedback Range -100 to 100
[[File:]] - Left
Range -100 to 100
[[File:]] - Right
Range -100 to 100
Fc9-comp-macro.png Backwards
Drives the robot backwards - waits for the distance to be traversed before returning
Distance in mm
Fc9-comp-macro.png EncoderReset
Resets the motor encoder counters
Fc9-comp-macro.png LCDVerbose
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on
0=Off 1=On
Fc9-comp-macro.png SetProp
Allows the COM port property to be set from a parent component.
Fc9-string-icon.png - STRING PropName
Fc9-u32-icon.png - ULONG PropVal
Fc9-comp-macro.png CardInit
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK
Fc9-comp-macro.png GetProp
Allows the property filter for the COM port list to be copied to a parent component.
Fc9-comp-macro.png LCDClear
Clears the LCD
Fc9-type-10-icon.png Host
Address of MQTT Broker Can be an IP Address or URL (URL only supported by some hardware platforms)
Fc9-type-21-icon.png Port
Port used by MQTT Broker Default 1883 for unencrypted access and 8883 for encrypted access.
Fc9-type-10-icon.png Client identifier
Client identifier (Maximum length 20 characters) Must be unique to the broker.
Fc9-type-21-icon.png Network Timeout
Maximum time in mS to wait for network responses
Fc9-type-21-icon.png Read Timeout
Time to wait in ms when waiting for incoming messages
Fc9-type-21-icon.png Keep Alive
The Keep Alive is the maximum time interval that is permitted to elapse between the point at which the Client finishes transmitting one Control Packet and the point it starts sending the next, measured in seconds.
Fc9-type-17-icon.png Network Component
Pointer to the network communications component providing TCP simulation and abstraction for embedded TCP modules.
Fc9-type-16-icon.png Authentication
Selects if the broker is open or if the broker requires a username and password.
Fc9-type-16-icon.png Number of topics
Sets the number of data topics that can be sent or received
Fc9-type-10-icon.png Topic String
Fc9-type-16-icon.png Topic Type
Fc9-conn-icon.png Simulations
