Component: MQTT Client (Comms: IoT/Cloud)
Revision as of 10:36, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.1
Category Comms: IoT/Cloud
MQTT Client component
A component providing access to MQTT IoT client. The client can connect to a MQTT server such as ThingSpeak. Allowing IoT type data to be published and read back.
The MQTT component requires connection to a Network Comms component via the "Network Component" property, to provide the bridge for simulated TCP/IP communication.
The Network Comms component can then be linked to an embedded TCP/IP component to provide embedded TCP/IP support.
Here is a typical setup for using MQTT on a Raspberry Pi.
Local Weather
A simple example demonstrating how to use MQTT with Flowcode SCADA to get the local weather conditions.
The example shows temperatures from Halifax in the UK and from Sydney in Australia.
FC6 Icon.png SCADA BBC TEMPERATURES
Publish
Raspberry Pi
Here we have an embedded Raspberry Pi project connected to an I2C Sensor, the sensor is sampled and the data is published to a MQTT server.
FC6 Icon.png RPI3 MQTT IOT EBM016
ESP8266 Module
Here we have an embedded project using an ESP8266 wifi module, an analogue input is sampled and the data is published to a MQTT server.
FC6 Icon.png MQTT IOT ESP8266
Subscribe
ESP8266 Module
Here we subscribe to a topic and receive it back into Flowcode embedded using an ESP8266 module.
FC6 Icon.png Subscribe ESP8266 MQTT
Flowcode App Developer
Here we subscribe to a topic and receive it back into Flowcode App Developer.
FC6 Icon.png Subscribe App Developer MQTT
Making your own Raspberry Pi based MQTT Broker
Click here for instructions on creating your own Raspberry Pi MQTT Broker.
Fc9-comp-macro.png GetTopic
Get the Topic of the last received (Read) packet. Returns the number of bytes for the Topic
Fc9-string-icon.png - STRING Topic
Fc9-u8-icon.png - BYTE Size
Byte count the Topic buffer
Fc9-comp-macro.png ErrorAsString
Fc9-u8-icon.png - BYTE Error
Fc9-comp-macro.png Connect
Connect to the MQTT Server. Returns the connected state. 0 if not connected, 1 if successful connection, or already connected.
Fc9-comp-macro.png Publish
Publish data to the server (broker) Returns non-zero if successful
Fc9-string-icon.png - STRING Payload
Fc9-comp-macro.png LastError
Returns the last error
Fc9-comp-macro.png Read
Read incoming data. Returns non-zero if packet received. Use GetTopic and GetPayload to read the contents.
Fc9-comp-macro.png Disconnect
Disconnects from the MQTT server and the network
Fc9-comp-macro.png Ping
Ping packet is sent to the Server and checks for a reply. Returns non-zero value if successful
Fc9-comp-macro.png GetPayload
Get the Payload of the last received (Read) packet. Returns the number of bytes for the Payload
Byte count the Payload buffer
Fc9-comp-macro.png Subscribe
Subscribe to a Topic. Must be Connected first Returns non-zero if successful
Fc9-comp-macro.png Unsubscribe
Unsubscribe from a Topic. Must be Connected first Returns non-zero if successful
Fc9-comp-macro.png Initialise
Fc9-comp-macro.png GetPayloadString
Get the Payload of the last received (Read) packet as a string value
Starts up the MQTT component - call this after initialising the NetworkComms component.
Sets up the GSM module. Returns 0 for OK, 255 for no reply and 254 for command fail.
Fc9-comp-macro.png Left
Rotates the robot left - waits for the angle to be traversed before returning
Fc9-u16-icon.png - UINT Angle
Angle to turn in degrees
Fc9-comp-macro.png ReadIR
Reads an IR sensor 0=Left, 1=FrontLeft, 2=Front, 3=FrontRight, 4=Right, 5=RearRight, 6=Rear, 7=RearLeft
Fc9-u8-icon.png - BYTE index
Fc9-comp-macro.png LCDDrawPixel
Allows a single pixel on the LCD to be set or cleared
Fc9-u8-icon.png - BYTE X
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y
Y Pixel 0-31
Fc9-u8-icon.png - BYTE State
0=White (Off), 1=Black (On)
Fc9-comp-macro.png ServoSetPosition
Allows one of the servo positions to be assigned
Range 0-3
Fc9-u8-icon.png - BYTE Position
Range 0-255
Fc9-comp-macro.png CardBitmap
Displays a monochrome bitmap read from the card on the LCD
Range 0-127
Range 0-31
Fc9-comp-macro.png CardRecordMic
Records an audio stream on the card from the microphone
Fc9-u8-icon.png - BYTE BitDepth
0=8-bit, 1=16-bit
Fc9-u8-icon.png - BYTE SampleRate
Sample Rate 0=8KHz, 1=16KHz
Fc9-u16-icon.png - UINT RecordTime
Time to record for in seconds, Range 0-65535
Fc9-comp-macro.png CardOpen
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK
Fc9-comp-macro.png Forwards
Drives the robot forwards - waits for the distance to be traversed before returning
Fc9-u16-icon.png - UINT Distance
Distance in mm
Fc9-comp-macro.png ReadBearing
Reads the compass bearing based on the degrees clockwise from magnetic north.
[[File:]] - Return
[[File:]] - Return
Fc9-comp-macro.png LCDDrawLine
Allows a single pixel width line to be drawn on the LCD
Fc9-u8-icon.png - BYTE X1
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y1
Y Pixel 0-31
Fc9-u8-icon.png - BYTE X2
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y2
Y Pixel 0-31
Fc9-comp-macro.png ServoAutoMoveToPosition
Allows one of the servo positions to move gradually to a new position
Range 0-3
Range 0-255
Fc9-comp-macro.png ReadAllValue
Reads a single value stored from the read all command Index dictates which sensor value to read
Fc9-u8-icon.png - BYTE Index
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel
Fc9-comp-macro.png LCDBacklight
Allows the LCD backlight brighntess to be adjusted
Fc9-u8-icon.png - BYTE Intensity
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
Fc9-comp-macro.png LCDDrawRect
Allows a rectangle to be drawn on the LCD
X Pixel 0-127
Y Pixel 0-31
X Pixel 0-127
Y Pixel 0-31
Fc9-comp-macro.png ReadLine
Reads one of the IR line sensors 0-1 0=Left, 1=Right
0=Left, 1=Right
Fc9-comp-macro.png ServoDisable
Allows one of the servo outputs 0-3 to be disabled
Range 0-3
Fc9-comp-macro.png ServoEnable
Allows one of the servo outputs 0-3 to be enabled
Range 0-3
Fc9-comp-macro.png CardReadByte
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end
Fc9-comp-macro.png CardErase
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK
Fc9-comp-macro.png CardWriteByte
Appends a byte to the end of the currently open file
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png EncoderRead
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit.
0=Left, 1=Right
Fc9-comp-macro.png SetMotors
Sets the motor speeds without feedback Range -100 to 100
[[File:]] - Left
Range -100 to 100
[[File:]] - Right
Range -100 to 100
Fc9-comp-macro.png Backwards
Drives the robot backwards - waits for the distance to be traversed before returning
Distance in mm
Fc9-comp-macro.png EncoderReset
Resets the motor encoder counters
Fc9-comp-macro.png LCDVerbose
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on
0=Off 1=On
Fc9-comp-macro.png SetProp
Allows the COM port property to be set from a parent component.
Fc9-string-icon.png - STRING PropName
Fc9-u32-icon.png - ULONG PropVal
Fc9-comp-macro.png CardInit
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK
Fc9-comp-macro.png GetProp
Allows the property filter for the COM port list to be copied to a parent component.
Fc9-comp-macro.png LCDClear
Clears the LCD
Fc9-type-10-icon.png Host
Address of MQTT Broker Can be an IP Address or URL (URL only supported by some hardware platforms)
Fc9-type-21-icon.png Port
Port used by MQTT Broker Default 1883 for unencrypted access and 8883 for encrypted access.
Fc9-type-10-icon.png Client identifier
Client identifier (Maximum length 20 characters) Must be unique to the broker.
Fc9-type-21-icon.png Network Timeout
Maximum time in mS to wait for network responses
Fc9-type-21-icon.png Read Timeout
Amount of time in ms to wait for incoming messages.
Fc9-type-21-icon.png Keep Alive
The Keep Alive is the maximum time interval that is permitted to elapse between the point at which the Client finishes transmitting one Control Packet and the point it starts sending the next, measured in seconds.
Fc9-type-17-icon.png Network Component
Pointer to the network communications component providing TCP simulation and abstraction for embedded TCP modules.
Fc9-type-16-icon.png Authentication
Selects if the broker is open or if the broker requires a username and password.
Fc9-conn-icon.png Simulations
