Component: DAC (Internal) (Analog Output)
Revision as of 10:36, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category Analog Output
DAC (Internal) component
Provides access to the onboard digital to analog converter (DAC) peripheral allowing for simple analogue output. Often the DAC output will be very low current and will need amplification using external circuitry to drive anything useful.
Fc9-comp-macro.png SetOutput
Sets the output voltage of the DAC
Fc9-u16-icon.png - UINT DAC_Value
The value to output to the DAC
Fc9-comp-macro.png GetValue
Gets the Name property value
Fc9-string-icon.png - STRING Name
The name of the property
Fc9-comp-macro.png Disable
Disables the DAC output.
Fc9-comp-macro.png Enable
Enables the DAC Output.
Fc9-comp-macro.png SetValue
Sets the Value for the named property
Name of property to update
Fc9-string-icon.png - STRING Value
The new value for the property
Fc9-comp-macro.png GetList
Fc9-comp-macro.png Unregister
Removes the object to the list if present
[[File:]] - Target
Fc9-comp-macro.png SetMovementFor
Sets the movement in units or PI/16 steps for the button
[[File:]] - Target
[[File:]] - Move
Movement to set to, default 4
Fc9-comp-macro.png CardBitmap
Displays a monochrome bitmap read from the card on the LCD
Fc9-u8-icon.png - BYTE X
Range 0-127
Fc9-u8-icon.png - BYTE Y
Range 0-31
Fc9-comp-macro.png CardRecordMic
Records an audio stream on the card from the microphone
Fc9-u8-icon.png - BYTE BitDepth
0=8-bit, 1=16-bit
Fc9-u8-icon.png - BYTE SampleRate
Sample Rate 0=8KHz, 1=16KHz
Fc9-u16-icon.png - UINT RecordTime
Time to record for in seconds, Range 0-65535
Fc9-comp-macro.png CardOpen
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK
Fc9-comp-macro.png Forwards
Drives the robot forwards - waits for the distance to be traversed before returning
Fc9-u16-icon.png - UINT Distance
Distance in mm
Fc9-comp-macro.png ReadBearing
Reads the compass bearing based on the degrees clockwise from magnetic north.
[[File:]] - Return
[[File:]] - Return
Fc9-comp-macro.png LCDDrawLine
Allows a single pixel width line to be drawn on the LCD
Fc9-u8-icon.png - BYTE X1
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y1
Y Pixel 0-31
Fc9-u8-icon.png - BYTE X2
X Pixel 0-127
Fc9-u8-icon.png - BYTE Y2
Y Pixel 0-31
Fc9-comp-macro.png ServoAutoMoveToPosition
Allows one of the servo positions to move gradually to a new position
Range 0-3
Fc9-u8-icon.png - BYTE Position
Range 0-255
Fc9-comp-macro.png ReadAllValue
Reads a single value stored from the read all command Index dictates which sensor value to read
Fc9-u8-icon.png - BYTE Index
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel
Fc9-comp-macro.png LCDBacklight
Allows the LCD backlight brighntess to be adjusted
Fc9-u8-icon.png - BYTE Intensity
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness
Fc9-comp-macro.png LCDDrawRect
Allows a rectangle to be drawn on the LCD
X Pixel 0-127
Y Pixel 0-31
X Pixel 0-127
Y Pixel 0-31
Fc9-comp-macro.png ReadLine
Reads one of the IR line sensors 0-1 0=Left, 1=Right
Fc9-u8-icon.png - BYTE index
0=Left, 1=Right
Fc9-comp-macro.png ServoDisable
Allows one of the servo outputs 0-3 to be disabled
Range 0-3
Fc9-comp-macro.png ServoEnable
Allows one of the servo outputs 0-3 to be enabled
Range 0-3
Fc9-comp-macro.png CardReadByte
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end
Fc9-comp-macro.png CardErase
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK
Fc9-comp-macro.png CardWriteByte
Appends a byte to the end of the currently open file
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png EncoderRead
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit.
0=Left, 1=Right
Fc9-comp-macro.png SetMotors
Sets the motor speeds without feedback Range -100 to 100
[[File:]] - Left
Range -100 to 100
[[File:]] - Right
Range -100 to 100
Fc9-comp-macro.png Backwards
Drives the robot backwards - waits for the distance to be traversed before returning
Distance in mm
Fc9-comp-macro.png EncoderReset
Resets the motor encoder counters
Fc9-comp-macro.png LCDVerbose
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on
Fc9-u8-icon.png - BYTE State
0=Off 1=On
Fc9-comp-macro.png SetProp
Allows the COM port property to be set from a parent component.
Fc9-string-icon.png - STRING PropName
Fc9-u32-icon.png - ULONG PropVal
Fc9-comp-macro.png CardInit
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK
Fc9-comp-macro.png GetProp
Allows the property filter for the COM port list to be copied to a parent component.
Fc9-comp-macro.png LCDClear
Clears the LCD
Fc9-type-16-icon.png Channel
DAC Channel number
Fc9-type-5-icon.png DAC Output Pin
DAC Output Pin
Fc9-type-16-icon.png Vref Option
Fc9-type-15-icon.png Vref Voltage
Fc9-type-14-icon.png Control Bits
Fc9-type-10-icon.png Resolution
Fc9-type-15-icon.png Voltage Resolution
Fc9-conn-icon.png Simulations
