Component: PicoScope (PS2000) (Test Equipment)
Revision as of 10:37, 17 November 2021 by Wiki bot (talk | contribs)
Category Test Equipment
PicoScope component
A set of functions designed for interacting with a 2000 series Pico scope via simulation.
An example project showing the capabilities of the Velleman K8055D board combined with a Pico Technology series 2 scope.
FC6 Icon.png Velleman and Picoscope Demo
Fc9-comp-macro.png ps2000_get_timebase
Returns details associated with the selected timebase index
[[File:]] - Handle
the handle of the required device.
[[File:]] - timebase
The ps2000a API allows you to select any of 2 32 different timebases based on a maximum sampling rate of 1 GS/s.
[[File:]] - no_of_samples
number of samples required
[[File:]] - time_interval
time interval between readings at the selected timebase. Use NULL if not required.
[[File:]] - time_units
[[File:]] - oversample
not used.
[[File:]] - max_samples
on exit, the maximum number of samples available.
[[File:]] - Return
Fc9-comp-macro.png ps2000_open_unit_progress
This function checks on the progress of a request made to ps2000aOpenUnitAsync to open a scope.
[[File:]] - handle
[[File:]] - Progress
[[File:]] - Return
Fc9-comp-macro.png ps2000_flash_led
This function flashes the LED on the front of the scope without blocking the calling thread.
[[File:]] - handle
handle of the scope device
[[File:]] - Return
Fc9-comp-macro.png ps2000_stop
This function stops the scope device from sampling data. If this function is called before a trigger event occurs, the oscilloscope may not contain valid data.
[[File:]] - Handle
[[File:]] - Return
Fc9-comp-macro.png ps2000_get_unit_info
This function retrieves information about the specified oscilloscope.
[[File:]] - Handle
the handle of the device
Fc9-string-icon.png - STRING info_string
unit information string
[[File:]] - string_length
the maximum number of chars in the string
[[File:]] - info_line
a number specifying what information is required. 0=DriverVersion / 1=USBVersion / 2=HardwareVersion / 3=VariantInfo / 4=BatchAndSerial / 5=CalDate / 6=KernelVersion / 7=DigHardwareVersion / 8=AnHardwareVersion
[[File:]] - Return
Fc9-comp-macro.png ps2000_set_channel
This function specifies whether an input channel is to be enabled, its input coupling type, voltage range, analog offset and bandwidth limit.
[[File:]] - handle
Handle of the device
[[File:]] - channel
the channel to be configured. The values are: 0=ChanA / 1=ChanB
[[File:]] - enabled
whether or not to enable the channel. The values are: 0=Disable / 1=Enable
[[File:]] - dc
the impedance and coupling type. Values: 0=AC / 1=DC
[[File:]] - range
the input voltage range: 0=50mV / 1=100mV / 2=200mV / 3=500mV / 4=1V / 5=2V / 6=5V / 7=10V / 8=20V
[[File:]] - Return
Fc9-comp-macro.png ps2000_get_times_and_values
[[File:]] - Handle
[[File:]] - times
[[File:]] - buffer_a
[[File:]] - buffer_b
[[File:]] - buffer_c
[[File:]] - buffer_d
[[File:]] - overflow
[[File:]] - Return
Fc9-comp-macro.png ps2000_set_trigger
[[File:]] - handle
[[File:]] - source
[[File:]] - threshold
[[File:]] - direction
[[File:]] - delay
[[File:]] - auto_trigger_ms
[[File:]] - Return
Fc9-comp-macro.png ps2000_set_sig_gen_built_in
sets up the signal generator to produce a signal from a list of built-in waveforms
[[File:]] - Handle
Handle to the device
[[File:]] - Offset_uV
the voltage offset, in microvolts, to be applied to the waveform
Fc9-u32-icon.png - ULONG pk2pk_uV
the peak-to-peak voltage, in microvolts, of the waveform
[[File:]] - waveType
the type of waveform to be generated. 0=Sine / 1=Square / 2=Triangle / 3=RampUp / 4=RampDown / 5=Sinc / 6=Gaus / 7=HalfSine / 8=DC
[[File:]] - startFrequency
the frequency that the signal generator will initially produce
[[File:]] - stopFrequency
the frequency at which the sweep reverses direction or returns to initial
[[File:]] - increment
the amount of frequency increase or decrease in sweep mode
[[File:]] - dwellTime
the time for which the sweep stays at each frequency, in seconds
[[File:]] - sweepType
whether the frequency will sweep from startFrequency to stopFrequency. 0=Up, 1=Down, 2=UpDown, 3=DownUp
Fc9-u32-icon.png - ULONG sweeps
produce number of cycles specified by shots
[[File:]] - Return
Fc9-comp-macro.png ps2000_close_unit
This function shuts down an oscilloscope.
[[File:]] - Handle
The handle of the scope device to be closed
[[File:]] - Return
Fc9-comp-macro.png ps2000_run_block
This function starts collecting data in block mode.
[[File:]] - handle
[[File:]] - time_indisposed_ms
[[File:]] - Return
Fc9-comp-macro.png ps2000_get_values
This function returns block-mode data, with or without downsampling.
[[File:]] - Handle
Start point for data collection
Number of samples
Down sample ratio
Down sample mode : 0=None / 1=Aggregate / 2=Decimate / 4=Average
Flags to indicate if an overflow has occurred
[[File:]] - Return
Fc9-comp-macro.png ps2000_ready
[[File:]] - Handle
[[File:]] - Return
Fc9-comp-macro.png ps2000_open_unit_async
This function opens a scope without blocking the calling thread.
[[File:]] - Return
Returns a handle to the opened unit Returns 0 if no unit found Returns -1 if unit failed to open
[[File:]] - Return
Fc9-comp-macro.png CommsBaud
Sets the Baud rate of the alt communications channel
Fc9-u8-icon.png - BYTE Baud
Range: 0-7 : 0=1200 / 7=115200
Fc9-comp-macro.png LCDOptions
Controls some of the LCD options
Fc9-u8-icon.png - BYTE Foreground
Range: 0-1
Fc9-u8-icon.png - BYTE Background
Range: 0-1
Range: 0-1
Fc9-comp-macro.png LCDVerbose
Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
Fc9-u8-icon.png - BYTE Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
Fc9-comp-macro.png ReadDigitalInput
Reads a single digital input.
Fc9-comp-macro.png PWMConfig
Sets the PWM configuration. Channel = 0 - 1 : 0 = EN_AB, A, B / 1 = EN_CD, C, D Period = 0 - 65535 Scaler = 0 - 3 : 0=1:1 1=1:8 2=1:64 3=1:256
Range 0-1
Fc9-u16-icon.png - UINT Period
Range: 0-65535
Fc9-u8-icon.png - BYTE Scaler
Range: 0-3
Fc9-comp-macro.png PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
Fc9-u8-icon.png - BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
Fc9-comp-macro.png PWMDuty
Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535
Range 0-5
Fc9-u16-icon.png - UINT Duty
Fc9-comp-macro.png LCDCursor
Sets the cursor position for the MIAC display
Fc9-u8-icon.png - BYTE X
Range: 0-21
Fc9-u8-icon.png - BYTE Y
Range: 0-4
Fc9-comp-macro.png WriteTran
Allows a single transistor output to be switched on or off.
Range 1-4
Fc9-u8-icon.png - BYTE Value
0 = Off, 1 = On
Fc9-comp-macro.png LCDClear
Clears the MIAC display
Clears the LCD
Fc9-conn-icon.png Simulations
