Component: RC5 (EB060, Generic 36KHz) (Wireless)
Revision as of 10:37, 17 November 2021 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 1.2
Category Wireless
RC5 (EB060, Generic 36KHz) component
Low level routines for controlling a standard RC5 IR interface. Also available in the form of the EB060 RC5 E-block.
Receive Data
Example to receive data via RC5 encoded IR. RC5 incoming data pin connected to pin RB0. If a valid RC5 packet is received then the 8-bit data is shown on the PORTD pins and the 5-bit address data is shown on the PORTA pins. FC6 Icon.png RC5 Receive Example
Transmit Data
Example to send data via RC5 encoded IR. The transmission is done via the RC0 pin and the modulation is performed by the PWM output signal on the RC2 pin. The data and address values are incremented after each transmission. FC6 Icon.png RC5 Transmit Example
Schematic showing the required hardware to combine TX masking pin and PWM output pin.
Fc9-comp-macro.png CollectData
Retreives a value from the last successful RC5 reception. 0 = Read Command 1 = Read Address 2 = Read Toggle Bit
Fc9-u8-icon.png - BYTE selection
Fc9-comp-macro.png RXDisable
Disables the RC5 data receive functionality.
Fc9-comp-macro.png TXPacket
Transmits a RC5 data packet consisting of command, address and toggle bit.
Fc9-u8-icon.png - BYTE command
Command to send 0-63
Fc9-u8-icon.png - BYTE address
Address to send 0-31
Fc9-u8-icon.png - BYTE toggle
Toggle bit value 0-1
Fc9-comp-macro.png TXEnable
Enables the RC5 data transmit functionality.
Fc9-comp-macro.png CheckRx
Checks to see if a new RC5 packet has been received. Returns 0 to signify no new data available. Returns 1 to signify there is new data available.
Fc9-comp-macro.png TXDisable
Disables the RC5 data transmit functionality.
Fc9-comp-macro.png RXEnable
Enables the RC5 data receive functionality.
Fc9-comp-macro.png CommsBaud
Sets the Baud rate of the alt communications channel
Fc9-u8-icon.png - BYTE Baud
Range: 0-7 : 0=1200 / 7=115200
Fc9-comp-macro.png LCDOptions
Controls some of the LCD options
Fc9-u8-icon.png - BYTE Foreground
Range: 0-1
Fc9-u8-icon.png - BYTE Background
Range: 0-1
Range: 0-1
Fc9-comp-macro.png LCDVerbose
Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
Fc9-u8-icon.png - BYTE Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
Fc9-comp-macro.png ReadDigitalInput
Reads a single digital input.
Fc9-comp-macro.png PWMConfig
Sets the PWM configuration. Channel = 0 - 1 : 0 = EN_AB, A, B / 1 = EN_CD, C, D Period = 0 - 65535 Scaler = 0 - 3 : 0=1:1 1=1:8 2=1:64 3=1:256
Range 0-1
Fc9-u16-icon.png - UINT Period
Range: 0-65535
Fc9-u8-icon.png - BYTE Scaler
Range: 0-3
Fc9-comp-macro.png PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
Fc9-u8-icon.png - BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
Fc9-comp-macro.png PWMDuty
Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535
Range 0-5
Fc9-u16-icon.png - UINT Duty
Fc9-comp-macro.png LCDCursor
Sets the cursor position for the MIAC display
Fc9-u8-icon.png - BYTE X
Range: 0-21
Fc9-u8-icon.png - BYTE Y
Range: 0-4
Fc9-comp-macro.png WriteTran
Allows a single transistor output to be switched on or off.
Range 1-4
Fc9-u8-icon.png - BYTE Value
0 = Off, 1 = On
Fc9-comp-macro.png LCDClear
Clears the MIAC display
Clears the LCD
Fc9-type-21-icon.png IR Frequency
The infra-red modulation frequency used when transmitting a logic one.
Fc9-type-16-icon.png Receive Mode
Specifies which receive mode the program should use.
Fc9-type-7-icon.png Invert Signal
Allows the incoming signal to automatically be inverted if needed by the receive hardware.
Fc9-type-16-icon.png Address Mask
What incoming values should we allow to make it through to the CheckRx macro.
Fc9-type-5-icon.png Receive Pin
Pin assigned to receive incoming RC5 data
Fc9-type-16-icon.png Transmit Mode
Specifies which transmit mode the program should use.
Fc9-type-10-icon.png Label
Fc9-conn-icon.png Simulations
