Component: RFID (EB052, RWD MICODE) (Wireless)
Revision as of 10:37, 17 November 2021 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Wireless
RFID (EB052, RWD-MICODE) component
Low level routines for controlling a RF Solutions RFID interface Allows communications between Mifare, ICode and HiTag type RFID tags. Also available in the form of the EB052 RFID E-block.
Reading the status
The status of the RFID module is read using the "GetRFIDStatus" macro which returns a byte which is then displayed using the PORTB pins. FC6 Icon.png RFID Status Status byte breakdown for Mifare.
Status byte breakdown for ICode.
Status byte breakdown for HiTag.
Status byte breakdown for EM Marin.
Reading and Writing Data
Example which talks to a ICode type card and allows the data to be read and written via a keypad. FC6 Icon.png RFID Read/Write
Macro compatibility
Not all the macros can be used with all card types, here is a list of RFID transponder types and the macros that are compatible.
Fc9-comp-macro.png GetRFIDTypeID
Collects the 3 bytes required to determine which kind of MIFARE device is present. Stores the result into the local buffer 0 - 2 and returns the response of the module.
Fc9-comp-macro.png WriteRFIDBlock
Writes a block of information to the RFID device.
Remote RFID Block Address.
Fc9-u8-icon.png - BYTE Key_Type
Fc9-comp-macro.png WriteRFIDModule
Stores a byte of data to the internal EEPROM of the RFID module at the address specified.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png DecrementRFIDValue
Perfoms a 32-bit decrement on the number held in location page or block.
Fc9-u8-icon.png - BYTE Src
Page / Block
Fc9-u8-icon.png - BYTE Dst
Page / Block
Needed for MIFARE Commands
Fc9-comp-macro.png FormatRFIDValue
Initialises the internal buffer of the Microcontroller so that it is ready to perform a Increment, Decrement or Transfer command.
Fc9-comp-macro.png IncrementRFIDValue
Perfoms a 32-bit increment on the number held in location page or block.
Page / Block
Page / Block
Fc9-comp-macro.png StoreRFIDKey
Stores a 6 byte key for use with MIFARE type devices that require authorisation.
Key Location 0 - 31
Fc9-u8-icon.png - BYTE D0
Least significant byte of key
Fc9-u8-icon.png - BYTE D1
Fc9-u8-icon.png - BYTE D2
Fc9-u8-icon.png - BYTE D3
Fc9-u8-icon.png - BYTE D4
Fc9-u8-icon.png - BYTE D5
Most significant byte of key
Fc9-comp-macro.png WriteRFIDBuffer
Writes a byte of data to the outgoing buffer.
The address of the buffer 0 - 15
The data to be stored in the buffer location 0 - 255.
Fc9-comp-macro.png GetRFIDStatus
Collect the status of the RFID device (see help for the explaination of the status byte).
Fc9-comp-macro.png ReadRFIDBuffer
Reads a byte of data from the incoming buffer.
Fc9-comp-macro.png TransferRFIDValue
Perfoms a 32-bit block data transfer on the number held in location page or block.
Page / Block
Page / Block
Fc9-comp-macro.png GetRFIDUID
Collects the UID from a RFID device. Stores the result into the UID buffer and returns the response of the module.
Fc9-comp-macro.png ReadRFIDUID
Reads a byte of data from the UID buffer.
The address of the buffer 0 - 7
Fc9-comp-macro.png ReadRFIDBlock
Reads a block of information from the RFID device.
Fc9-comp-macro.png Initialise
Configures the RFID device by presetting the Osc type and Mode via the Flowcode component properties.
Fc9-comp-macro.png ReadRXSignalStrength
Returns the current received signal strength.
Fc9-comp-macro.png Uninitialise
Powers down the RF module. The module must be re-initialised before it can be used again.
Fc9-comp-macro.png CheckBuffer
Checks for incoming data for a specific period of time. Returns a value greater then 250 to indicate a failure. Returns the length of the incoming data buffer to indicate success.
Fc9-u8-icon.png - BYTE Timeout
Time to wait before returning no data available
Fc9-comp-macro.png GetBufferData
Returns a value from the incoming receive data buffer.
Fc9-u8-icon.png - BYTE Index
Specifies which position in the buffer to read data from
Fc9-comp-macro.png ReceiveString
Puts the RF module in data mode and attempts to receive a string of bytes from the RF connection.
Fc9-u8-icon.png - BYTE Length
Specifies the maximum number of bytes to try and receive
Specifies how many milliseconds to wait for valid data before returning.
Starts up and configures the RF module ready for use. The macro will return a value greater then 0 if the module has been started correctly, otherwise the macro will return a 0.
Sets up the 1-Wire output pin ready for communications.
Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0.
Initialises the MIDI component and sets up the UART.
Fc9-comp-macro.png CommsBaud
Sets the Baud rate of the alt communications channel
Fc9-u8-icon.png - BYTE Baud
Range: 0-7 : 0=1200 / 7=115200
Fc9-comp-macro.png LCDOptions
Controls some of the LCD options
Fc9-u8-icon.png - BYTE Foreground
Range: 0-1
Fc9-u8-icon.png - BYTE Background
Range: 0-1
Range: 0-1
Fc9-comp-macro.png LCDVerbose
Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
Fc9-u8-icon.png - BYTE Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
Fc9-comp-macro.png ReadDigitalInput
Reads a single digital input.
Fc9-comp-macro.png PWMConfig
Sets the PWM configuration. Channel = 0 - 1 : 0 = EN_AB, A, B / 1 = EN_CD, C, D Period = 0 - 65535 Scaler = 0 - 3 : 0=1:1 1=1:8 2=1:64 3=1:256
Range 0-1
Fc9-u16-icon.png - UINT Period
Range: 0-65535
Fc9-u8-icon.png - BYTE Scaler
Range: 0-3
Fc9-comp-macro.png PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
Fc9-u8-icon.png - BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
Fc9-comp-macro.png PWMDuty
Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535
Range 0-5
Fc9-u16-icon.png - UINT Duty
Fc9-comp-macro.png LCDCursor
Sets the cursor position for the MIAC display
Fc9-u8-icon.png - BYTE X
Range: 0-21
Fc9-u8-icon.png - BYTE Y
Range: 0-4
Fc9-comp-macro.png WriteTran
Allows a single transistor output to be switched on or off.
Range 1-4
Fc9-u8-icon.png - BYTE Value
0 = Off, 1 = On
Fc9-comp-macro.png LCDClear
Clears the MIAC display
Clears the LCD
Fc9-type-16-icon.png Card_Type
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-5-icon.png CTS
Fc9-conn-icon.png Simulations
Fc9-type-10-icon.png Label
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
