Component: MULTIUART (SPI2UART) (Comms: System)
Revision as of 10:37, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category Comms: System
MULTIUART component
Uses a high speed SPI connection to enable up to four buffered external UARTs via the MULTIUART modules.
FC6 Icon.png Simple test program
Fc9-comp-macro.png ReceiveByte
Returns the first received byte held in queue for the selected channel. Recommended to use the CheckRx macro first to collect number of bytes.
Fc9-u8-icon.png - BYTE UART
UART Index Range: 0-3
Fc9-comp-macro.png TransmitString
Adds a byte to the transmit queue for the selected channel.
Fc9-comp-macro.png SetBaud
Fc9-u8-icon.png - BYTE Baud
Fc9-comp-macro.png TransmitByte
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png CheckRx
Returns the number of received bytes held in queue for the selected channel.
Fc9-comp-macro.png CheckTx
Returns the number of bytes held in the transmit queue for the selected channel.
Fc9-comp-macro.png ReceiveString
Returns a string of received bytes held in queue for the selected channel. Recommended to use the CheckRx macro first to collect number of bytes.
Fc9-u8-icon.png - BYTE NumBytes
Fc9-comp-macro.png Initialise
Activates the SPI peripheral and claims control over the I/O pins.
Fc9-comp-macro.png I2CRestart
Fc9-comp-macro.png WIFIIsConnected
Checks to see if the WIFI is active and connected
[[File:]] - Return
Fc9-comp-macro.png PWMDisable
Disable a PWM output
Range: 0-1
Fc9-comp-macro.png I2CStart
Fc9-comp-macro.png SPITransfer
Fc9-comp-macro.png I2CReceive
[[File:]] - Last
Fc9-comp-macro.png I2CStop
Fc9-comp-macro.png WIFISetSSID
Assign the SSID and password for the network you wish to connect the board to. Stores the parameters into ROM for later USB free setup.
Fc9-string-icon.png - STRING SSID
Name of the network you wish to connect to
Fc9-string-icon.png - STRING Password
Fc9-comp-macro.png ServoDisable
Disable a Servo output
Range: 0-5
Fc9-comp-macro.png SPIPrescaler
Range: 0-2
Fc9-comp-macro.png ServoEnable
Enable a Servo output
Range: 0-5
Fc9-comp-macro.png ADCSample10
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023
Fc9-u8-icon.png - BYTE ADCChannel
Range: 0-5
Fc9-comp-macro.png I2CTransSend
Data to send
Fc9-u16-icon.png - UINT Count
Fc9-comp-macro.png I2CTransInit
Fc9-u8-icon.png - BYTE DeviceAddress
7-bit Device Address
0=100KHz, 1=400KHz, 2=1MHz
Fc9-comp-macro.png IOSetOutputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-17
[[File:]] - State
Range: 0-1
Fc9-comp-macro.png ServoSetPosition8
Sets the position as an 8-bit value
Range: 0-1
Fc9-u8-icon.png - BYTE Position
Range: 0-255
Fc9-comp-macro.png SPIInitialise
Fc9-comp-macro.png WIFIGetIP
Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active.
Fc9-comp-macro.png I2CSend
[[File:]] - Return
Fc9-comp-macro.png UARTSend
Fc9-comp-macro.png PWMSetPrescaler
Fc9-comp-macro.png PWMSetDuty8
Range: 0-1
Fc9-u8-icon.png - BYTE Duty
Range: 0-255
Fc9-comp-macro.png PWMEnable
Enable a PWM output
Range: 0-1
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
Fc9-u8-icon.png - BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
Fc9-comp-macro.png LCDClear
Clears the MIAC display
Clears the LCD
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-conn-icon.png Simulations
Fc9-type-10-icon.png Label
Label used to identify the component on the panel.
Fc9-type-16-icon.png API
