Component: Property Manager (Storage )
Version | 1.0 |
Category | Storage |
Property Manager component
Allows property values exposed to the user to be saved and loaded using an external file. Simplifies the process of storing and retreiving the property values. Also works with nested properties using the "::" syntax.
Save |
Saves the registered property values to the config file. | |
Return |
Load |
Loads the registered property values from the config file. | |
Return |
ClearBuffer |
Erases the contents of the buffer | |
Return |
GetLastIncoming |
Gets a value from the last incoming command. Index 0 = 0 Read / 1 Write Index 1 = 0 Coils / 1 DigInput / 2 AnInput / 3 Register Index 2 = Address Index 3 = Number | |
Return |
SetAnalogInput |
Sets the state of a single analogue input. | |
Address |
Coil Address | |
Value |
Analogue Value range 0 - 65535 | |
Return |
Initialise |
Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0. | |
Return |
ReadFileSize |
Reads the entire size of the current file in bytes. | |
Return |
SetTimeAndDate |
Sets the current time and date. Time = (Hour << 11) + (Min << 5) + (Sec >> 1) Date = (YearFrom1980 << 9) + (Month << 5) + (Day) Additional details can be found here: http://www.maverick-os.dk/FileSystemFormats/FAT16_FileSystem.html#TimeFormat | |
Time |
Sets the current Time in FAT Time format hhhhhmmmmmmsssss - S=Secs/2 | |
Date |
Sets the current Date in FAT Date format yyyyyyymmmmddddd - Y=Years since 1980 | |
Return |
Initialise |
Attempts to communicate with the SD card and if successful sets up the file system. Returns 0 for success. | |
Return |
Initialise |
Initialise the comms to the Arduino board ready for commands to be sent. | |
Return |
ReadAnalogInput |
Reads a single digital input. | |
Channel |
Return |
Initialise |
Return |
LCDClear |
Clears the MIAC display | |
Return |
LCDClear |
Clears the LCD | |
Return |
