Component: API (Arduino Mega) (API Slave Devices)
Author | Matrix TSL |
Version | 2.0 |
Category | API Slave Devices |
API (Arduino Mega) component
Connects to an Arduino Mega running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / UART / PWM See Flowcode Help Wiki for firmware.
The App Developer (Arduino Mega) component allows an Arduino Mega board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the Arduino Mega hardware the board must first be pre-programmed with dedicated firmware.
The firmware hex file and Flowcode source project can be downloaded from here.
Arduino Mega App Developer Firmware
The COM port to the Arduino hardware is selected via the SCADA_Ard_Mega component COM port property.
When building the component into a App Developer project remember to expose the COM port property to allow the end user to select the correct port for the hardware.
- fixed statistics showing IO / ADC inputs / PWM
- scrolling log showing all commands and returns
Pin Mapping
App Developer Slave Digital Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 | 28 | 29 | 30 | 31 | 32 | 33 | 34 | 35 | 36 | 37 | 38 | 39 | 40 | 41 | 42 | 43 | 44 | 45 | 46 | 47 | 48 | 49 |
Device Port Pin | E0 | E1 | E2 | E5 | G5 | E3 | H3 | H4 | H6 | H6 | B4 | B5 | B6 | B7 | J1 | J0 | H1 | H0 | D3 | D2 | D1 | D0 | A0 | A1 | A2 | A3 | A4 | A5 | A6 | A7 | C7 | C6 | C5 | C4 | C3 | C2 | C1 | C0 | D7 | G2 | G1 | G0 | L7 | L6 | L5 | L4 | L3 | L2 | L1 | L0 |
Arduino Style Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | 17 | 18 | 19 | 20 | 21 | 22 | 23 | 24 | 25 | 26 | 27 | 28 | 29 | 30 | 31 | 32 | 33 | 34 | 35 | 36 | 37 | 38 | 39 | 40 | 41 | 42 | 43 | 44 | 45 | 46 | 47 | 48 | 49 |
App Developer Slave Analogue Pin | 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 |
Device Port Pin | F0 | F1 | F2 | F3 | F4 | F5 | F6 | F7 | K0 | K1 | K2 | K3 | K4 | K5 | K6 | K7 |
Arduino Style Pin | A0 | A1 | A2 | A3 | A4 | A5 | A6 | A7 | A8 | A9 | A10 | A11 | A12 | A13 | A14 | A15 |
App Developer Slave Peripheral Pin | I2C 0 SDA | I2C 0 SCL | SPI 0 MOSI | SPI 0 MISO | SPI 0 SCK | UART 0 RX | UART 0 TX | UART 1 RX | UART 1 TX | UART 2 RX | UART 2 TX | PWM 0 | PWM 1 | PWM 2 | PWM 3 | PWM 4 | PWM 5 | PWM 6 | PWM 7 | PWM 8 | PWM 9 | PWM 10 | PWM 11 | PWM 12 | PWM 13 | PWM 14 | PWM 15 |
Device Port Pin | D1 | D0 | B3 | B4 | B5 | D2 | D3 | H0 | H1 | J0 | J1 | B7 | G5 | B5 | B6 | B7 | B4 | H6 | E3 | E4 | E5 | H3 | H4 | H5 | L3 | L4 | L5 |
Arduino Style Pin | D20 | D21 | D50 | D10 | D11 | D19 | D18 | D17 | D16 | D15 | D14 | D13 | D4 | D11 | D12 | D13 | D10 | D9 | D5 | D2 | D3 | D6 | D7 | D8 | D46 | D45 | D44 |
I2CInitialise |
Initialsie the I2C module ready for communications | |
Channel |
Channel Index: Range 0 - I2C Bus Count - 1 | |
Baud |
0=100KHz, 1=400KHz, 2=1MHz | |
Return |
IOGetInputPin |
Sets the selected digital pin to an input and reads the input state. | |
Pin |
Range: 0-53 | |
[[File:]] - | Return |
ADCSample8 |
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 | |
ADCChannel |
Range: 0-15 | |
Return |
UARTCheckRX |
Check to see if the UART module has received any data | |
Channel |
Channel Index: Range 0 - UART Bus Count - 1 | |
Return |
UARTInitialise |
Initialise the UART module ready for communications | |
Channel |
Return |
RegisterWrite |
Writes to one of the registers on-board the device | |
RegisterAddress |
The address of the register | |
Data |
The data value to assign to the register | |
Return |
RegisterRead |
Read one of the registers on-board the device | |
RegisterAddress |
Return |
I2CRestart |
Put the I2C Module into Restart mode | |
Channel |
Return |
PWMDisable |
Disable a PWM output | |
Channel |
Range: 0-15 | |
Return |
I2CStart |
Put the I2C Module into Start mode | |
Channel |
Return |
SPITransfer |
Transfer a byte using the SPI bus | |
Channel |
Channel Index: Range 0 - SPI Bus Count - 1 | |
DataOut |
Return |
I2CReceive |
Receive a byte using the I2C bus | |
Channel |
[[File:]] - | Last |
Last byte to receive: Range 0-1 | |
Return |
I2CStop |
Put the I2C Module into Stop mode | |
Channel |
Return |
ADCSetReferenceVoltage |
Specified the reference setting for ADC reads. | |
RefType |
0=AREF, 1=VCC, 3=Internal 1.1V | |
Return |
SPIPrescaler |
Modify the speed of the SPI bus | |
Channel |
Prescaler |
Range: 0-2 | |
Return |
PWMSetDuty |
Sets the duty for the PWM output | |
Channel |
Range: 0-15 | |
Duty |
Return |
ADCSample10 |
Reads the voltage present on an Analog pin as an 10-bit value range 0-1023 | |
ADCChannel |
Range: 0-15 | |
Return |
IOSetOutputPin |
Sets the selected digital pin to an output and assigns the output state. | |
Pin |
Range: 0-53 | |
[[File:]] - | State |
Range: 0-1 | |
Return |
UARTReceive |
Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available. | |
Channel |
Return |
SPIInitialise |
Initialsie the SPI module ready for communications | |
Channel |
Return |
I2CSend |
Transmit a byte using the I2C bus | |
Channel |
DataOut |
UARTSend |
Send a byte via the UART module | |
Channel |
Data |
Data Byte to send. Range: 0-255 | |
Return |
PWMSetPrescaler |
Sets the prescaler for the PWM output | |
Channel |
Range: 0-15 | |
Prescaler |
Period |
Default 255 | |
Return |
PWMEnable |
Enable a PWM output | |
Channel |
Range: 0-15 | |
Return |
Initialise |
Initialise the comms to the Arduino board ready for commands to be sent. | |
Return |
Initialise |
The Init macro must be called once to initialise the Graphical LCD display before any other Graphical LCD component macros are called. | |
Return |
Initialise |
Return |
