Component: Accel / Mag 6 Axis (EBM015) (EBM Modules)
Version | 2.0 |
Category | EBM Modules |
Accel / Mag 6-Axis component
EBM015 Combined 6-Axis Accelerometer and Magnetometer sensors Useful for working out data such as Pitch and Yaw.
Sample program using the EBM015 - Magnetometer sensor.
Reads either the accelerometer or compass data and displays on the LCD.
SimReset1G |
Return |
UpdateCompassData |
Reads from the compass and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
Return |
SimSetAccelerometer |
Allows the XYZ slider values to be set via the simulation | |
[[File:]] - | X |
[[File:]] - | Y |
[[File:]] - | Z |
Return |
UpdateAccelerometerData |
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
Return |
SimSetCompass |
[[File:]] - | X |
[[File:]] - | Y |
[[File:]] - | Z |
Return |
Initialise |
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
Return |
SimSetGyro |
[[File:]] - | X |
[[File:]] - | Y |
[[File:]] - | Z |
Return |
Return |
SimSetCompass |
[[File:]] - | X |
[[File:]] - | Y |
[[File:]] - | Z |
Return |
Initialise |
Return |
IOSetOutputPin |
Sets the selected digital pin to an output and assigns the output state. | |
Pin |
Range: 0-29 | |
[[File:]] - | State |
Range: 0-1 | |
Return |
UARTReceive |
Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available. | |
Channel |
Channel Index: Range 0 - UART Bus Count - 1 | |
Return |
OneWireScanBus |
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
Channel |
Channel Index: Range 0 - I2C Bus Count - 1 | |
Return |
SPIInitialise |
Initialsie the SPI module ready for communications | |
Channel |
Channel Index: Range 0 - SPI Bus Count - 1 | |
Return |
OneWireReceiveByte |
Receives a byte from the one wire bus a bit at a time | |
Channel |
Return |
I2CSend |
Transmit a byte using the I2C bus | |
Channel |
DataOut |
[[File:]] - | Return |
UARTSend |
Send a byte via the UART module | |
Channel |
Data |
Data Byte to send. Range: 0-255 | |
Return |
OneWireGetDeviceCount |
Returns the number of devices found by the last ScanBus operation. | |
Channel |
Return |
PWMSetPrescaler |
Sets the prescaler for the PWM output | |
Channel |
Range: 0 - 11 | |
Prescaler |
Period |
Return |
PWMEnable |
Enable a PWM output | |
Channel |
Range: 0-11 | |
Return |
Initialise |
Initialise the comms to the Arduino board ready for commands to be sent. | |
Return |
Initialise |
Return |
