Author
Matrix TSL
Version
1.6
Category
Movement & Orientation
Magnetometer 3-Axis component
HMC5883L 3-Axis Magnetometer sensor Useful for working out data such as compass orientation.
Here is a very simple demonstration on how to use the sensor to read X, Y, Z magnetometer data from the sensor.
HMC5883L Demo
Read_Register
Reads a value from a register on the accelerometer.
- BYTE
Reg
- BYTE
Write_Register
Writes a data value to a specific register on the accelerometer
- BYTE
Reg
- BYTE
Data
- BYTE
UpdateCompassData
Reads from the compass and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
- BYTE
CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE
Axis
[[File:]] -
SimSetCompass
Allows the XYZ slider values to be set via the simulation
[[File:]] -
X
[[File:]] -
Y
[[File:]] -
Z
Read_Bearing
Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
- BYTE
NumSamples
The number of readings to base the bearing on
- UINT
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
- BYTE
Configures the I2C peripheral and puts the sensor into one shot mode ready to be sampled. Must be called before calling any of the other component macros. Returns 1 if the sensor has been intialised correctly, else returns 0.
- BYTE
- BYTE
SimSetGyro
[[File:]] -
X
[[File:]] -
Y
[[File:]] -
Z
UpdateAccelerometerData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
- BYTE
SimSetCompass
[[File:]] -
X
[[File:]] -
Y
[[File:]] -
Z
Read_Bearing
- BYTE
NumSamples
- UINT
- BYTE
IOSetOutputPin
- BYTE
Pin
Range: 0-29
[[File:]] -
State
Range: 0-1
UARTReceive
- BYTE
- BYTE
ADCSampleAverage10
- BYTE
ADCChannel
Range: 0, 3-7
- BYTE
SampleCount
Range: 1- 100
- BYTE
SampleDelay
- UINT
OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
- BYTE
- BYTE
SPIInitialise
- BYTE
OneWireReceiveByte
- BYTE
- BYTE
I2CSend
- BYTE
- BYTE
DataOut
[[File:]] -
UARTSend
- BYTE
- BYTE
Data
OneWireGetDeviceCount
- BYTE
- BYTE
PWMSetPrescaler
- BYTE
Range: 0 - 11
- BYTE
Prescaler
- BYTE
Period
PWMEnable
Enable a PWM output
- BYTE
Range: 0-11
ADCSampleArray10
- BYTE
ADCChannel
Range: 0, 3-7
- BYTE
SampleCount
Range: 1- 32
- UINT
SampleDelay
- UINT
Samples
ADCSampleAverage8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples
- BYTE
ADCChannel
Range: 0, 3-7
- BYTE
SampleCount
Range: 1- 100
- BYTE
SampleDelay
- BYTE
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE
EnableMask
Range 0-63 or 0b00000 to 0b111111
Bit Depth
Measurement Mode
Continuous mode makes constant sensor readings setting the RDY pin when new data is available. Single mode does a single sensor read setting the RDY pin when done and then waits for data to be read.
Num Samples
The number of samples that are averaged together to provide the readings.
Compass Data Rate
Sets the output conversion rate.
Compass Scale
API
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Use RDY Pin
Simulations
Simulate Comms
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the I2C CAL component - Injector etc
