Component: Temperature (LM75B) (Environmental)
Revision as of 10:39, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category Environmental
Temperature component
A digital temperature sensor based around the NXP LM75B chip.
Fc9-comp-macro.png ReadInt
Read double byte data from register at address
Fc9-u8-icon.png - BYTE address
[[File:]] - Return
Fc9-comp-macro.png ReadFloat
Reads the temperature value as a float
[[File:]] - Return
Fc9-comp-macro.png WriteByte
Fc9-u8-icon.png - BYTE data
Fc9-comp-macro.png WriteInt
Fc9-u16-icon.png - UINT data
Fc9-comp-macro.png ReadByte
Read a single byte at a specific address from the chip's internal memory.
Fc9-comp-macro.png Uninit
Uninitialise and release resources
Fc9-comp-macro.png Initialise
Initialise to default of 11 bit resolution
Configures each matching sensor on the bus with the specified conversion bits.
Fc9-comp-macro.png WriteRegister
A simple example showing a generic way to write a register using I2C.
Fc9-u8-icon.png - BYTE Data
[[File:]] - Return
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
Fc9-comp-macro.png IOSetOutputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-29
[[File:]] - State
Range: 0-1
Fc9-comp-macro.png ADCSampleAverage10
Fc9-u8-icon.png - BYTE ADCChannel
Range: 0, 3-7
Fc9-u8-icon.png - BYTE SampleCount
Range: 1- 100
Fc9-u8-icon.png - BYTE SampleDelay
Fc9-comp-macro.png OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
Fc9-comp-macro.png SPIInitialise
Fc9-comp-macro.png OneWireReceiveByte
Fc9-comp-macro.png I2CSend
[[File:]] - Return
Fc9-comp-macro.png UARTSend
Fc9-comp-macro.png OneWireGetDeviceCount
Fc9-comp-macro.png PWMSetPrescaler
Range: 0 - 11
Fc9-u8-icon.png - BYTE Period
Fc9-comp-macro.png PWMEnable
Enable a PWM output
Range: 0-11
Fc9-comp-macro.png ADCSampleArray10
Range: 0, 3-7
Range: 1- 32
Fc9-u16-icon.png - UINT SampleDelay
Fc9-u16-icon.png - UINT Samples
Fc9-comp-macro.png ADCSampleAverage8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples
Range: 0, 3-7
Range: 1- 100
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
Fc9-u8-icon.png - BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-type-16-icon.png API
Fc9-conn-icon.png Simulations
Fc9-type-7-icon.png Simulation Comms
Fc9-type-15-icon.png Min. Temp.
Minimum termperature that can be set or displayed on the thermometer slider.
Fc9-type-15-icon.png Max. Temp.
Maximum termperature that can be set or displayed on the thermometer slider.
Fc9-type-21-icon.png Scale divisions
Number of numbered divisions shown on the thermometer scale.
Fc9-type-16-icon.png I2C Data
Set whether the I2C data is displayed as decimal or hexadecimal numbers.
