Component: Thermocouple ( MCP960X) (Environmental)
Revision as of 10:39, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.1
Category Environmental
Thermocouple component
Component to interface the MCP960X IC from Microchip. Uses a standard 2-wire I2C interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Here is a basic example to display both the thermocouple temperature and IC surface temperature.
FC6 Icon.png MCP960X Demo
Sim Demo
Fc9-comp-macro.png ReadReference_Int
Returns the Reference (IC die) temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures.
[[File:]] - Return
Fc9-comp-macro.png ReadRawDataADC
Returns the thermocouple temperature from the last sample as an integer value in Degrees C.
[[File:]] - Return
Fc9-comp-macro.png ReadReference_Float
Returns the reference (IC die) temperature from the last sample as a floating point. Use Sample first, which samples both reference & themocouple temperatures.
[[File:]] - Return
Fc9-comp-macro.png Sample
Must be called before any of the Read functions. Reads the memory of the MCP9600/1 IC. Returns 0 for 9600. Checks for errors, MCP9601 only. Returns: 0 = OK, 1 = O/ C Themocouple & 2=S/C Themocouple.
Fc9-comp-macro.png ReadRegister
Reads a byte from a register
Fc9-comp-macro.png ReadThermocouple_Int
Returns the thermocouple temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures.
[[File:]] - Return
Fc9-comp-macro.png ReadThermocouple_Float
Returns the thermocouple temperature from the last sample as a floating point value. Use Sample first, which samples both reference & themocouple temperatures.
[[File:]] - Return
Fc9-comp-macro.png WriteRegister
Writes a byte to a register
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png Initialise
Configures the I2C bus ready for communications.
Configures each matching sensor on the bus with the specified conversion bits.
A simple example showing a generic way to write a register using I2C.
[[File:]] - Return
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
Fc9-comp-macro.png IOSetOutputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-29
[[File:]] - State
Range: 0-1
Fc9-comp-macro.png ADCSampleAverage10
Fc9-u8-icon.png - BYTE ADCChannel
Range: 0, 3-7
Fc9-u8-icon.png - BYTE SampleCount
Range: 1- 100
Fc9-u8-icon.png - BYTE SampleDelay
Fc9-comp-macro.png OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
Fc9-comp-macro.png SPIInitialise
Fc9-comp-macro.png OneWireReceiveByte
Fc9-comp-macro.png I2CSend
[[File:]] - Return
Fc9-comp-macro.png UARTSend
Fc9-comp-macro.png OneWireGetDeviceCount
Fc9-comp-macro.png PWMSetPrescaler
Range: 0 - 11
Fc9-u8-icon.png - BYTE Period
Fc9-comp-macro.png PWMEnable
Enable a PWM output
Range: 0-11
Fc9-comp-macro.png ADCSampleArray10
Range: 0, 3-7
Range: 1- 32
Fc9-u16-icon.png - UINT SampleDelay
Fc9-u16-icon.png - UINT Samples
Fc9-comp-macro.png ADCSampleAverage8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples
Range: 0, 3-7
Range: 1- 100
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
Fc9-u8-icon.png - BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
Fc9-type-16-icon.png Thermocouple Type
Thermocouple type. Selects which type of thermocouple the IC works with.
Fc9-type-16-icon.png Filter Coefficients
Digitial filter selection. The higher the number the better the filter. Results more stable but take longer to update.
Fc9-type-16-icon.png Unit
Select Temperature results to be celsius or fahrenheit
Fc9-type-21-icon.png Address
Address ranges 0x60 - 0x67 (96 - 103)
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-type-16-icon.png API
Fc9-conn-icon.png Simulations
