Author
Matrix Ltd
Version
1.5
Category
Storage
Circular Buffer (Float) component
Circular buffer component allowing easy and efficient first in first out (FIFO) style data storage. Also features macros to allow you to check for specific floating point values.
WaitForValues
Waits for an array of values to appear in the circular buffer. Returns 0 to indicate a timeout. Returns 1 to indicate the data has been found.
[[File:]] -
Values
- BYTE
NumValues
Number of values to try and look for
- BYTE
RemoveContent
0=Leave the buffer contents untouched, 1=Remove values as you go
- UINT
Timeout
Max amount of time to wait in milliseconds before returning 0=WaitForever
- BYTE
GetNumberValues
Returns the number of valid 16-bit data values currently stored inside the buffer.
- UINT
PeekData
Reads the next available 16-bit data value from the circular buffer without advancing the current index, Returns the default value if the buffer is empty.
[[File:]] -
PutData
Add a 32-bit floating point value to the next free location inside the circular buffer. If the data goes into the buffer correctly then return 1. Otherwise the buffer is full and the return value will equal 0.
[[File:]] -
Data
- BYTE
LookForValues
Scans the buffer for an array of specific values. Returns 0 if the value is not found. Returns 1 if the value is found.
[[File:]] -
Values
- BYTE
NumValues
The number of values you wish to try and match
- BYTE
RemoveContent
0=Leave data alone, 1=Remove data from buffer
- BYTE
ResetFind
0=Continue the find from the last operation, 1=Start again
- BYTE
GetData
Reads the next available 32-bit floating point value from the circular buffer, Returns the default value if the buffer is empty.
[[File:]] -
FlushBuffer
Clears the contents of the buffer and re-initialises the index locations.
GetIndexedValue
Gets the value of a single 32-bit floating point value at a known location in the buffer. Leaves the buffer contents and pointers untouched.
- UINT
address
[[File:]] -
FlushBuffer
GetConsoleHandle
[[File:]] -
SendByteArray
Sends an array of bytes to the COM port.
- BYTE
Data
Data byte array to send
- UINT
Length
Number of bytes to send
ReceiveBinary16Bit
Receives a binary 16-bit value split across two bytes.
[[File:]] -
MSBfirst
0=Least significant byte first, 1=Most significant byte first
- BYTE
Timeout
Max amount of time in ms to wait between bytes
- UINT
ReceiveFloat
Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE
Timeout
Max time in ms to wait in between bytes
[[File:]] -
IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
[[File:]] -
SendFloat
Sends out a floating point number as an ASCII String from the UART interface.
[[File:]] -
Number
SendHexNumber
Sends out a number as an ASCII hexadecimal String from the UART interface.
- ULONG
Number
- BYTE
NumChars
Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
[[File:]] -
Prefix
Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SetFlowControl
Allows the Flowcontrol signals to be enabled or disabled.
- BYTE
State
A value of 0 disables flow control, 1 or above willl enable flow control.
OpenPort
Opens the currently selected COM port, allowing data to be sent and received.
ReceiveHexNumber
Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
- BYTE
Timeout
[[File:]] -
IgnoreData
[[File:]] -
Prefix
Look for prefix before receiving, 1=0xFF, 0=FF
- ULONG
SetProp
Allows the COM port property to be set from a parent component.
- STRING
PropName
- ULONG
PropVal
SendBinary32Bit
Sends out a 32-bit binary value split across four bytes.
- ULONG
Value
[[File:]] -
MSBfirst
SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
[[File:]] -
Value
[[File:]] -
MSBfirst
GetProp
Allows the property filter for the COM port list to be copied to a parent component.
- STRING
PropName
- STRING
ReceiveByteArray
Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
- BYTE
Data
- UINT
MaxLength
Max number of bytes to try and read
- UINT
Timeout
Time to wait for incoming data in milliseconds
- UINT
ReceiveString
Attempts to receive an string using the COM port Returns the number of bytes received.
- UINT
Timeout
- UINT
MaxLength
- STRING
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE
EnableMask
Range 0-63 or 0b00000 to 0b111111
GetProp
- STRING
PropName
- STRING
Buffer Size
Sets the number of byte elements inside the circular buffer.
Storage Type
When buffer is full this property decides what to do. Store first x values - Will retain the information inside the buffer, new data will be discarded. Store last x values - Will discard the oldest location in the buffer and overwrite with new data.
Memory Type
Default Return Data
Specifies the value returned by the receive function when there is no data held in the buffer
Simulations
