Author
MatrixTSL
Version
1.0
Category
Storage
EEPROM (DS28E07) component
A rugged EEPROM allowing one or more devices to be addressed and accessed. Requires a One Wire component to perform the bus operations.
SetString
Writes a string to the EE memory starting at the selected address. All bytes from the string will be written including the null termination.
- UINT
Address
Address of the value to write
- STRING
Value
Data string to write
GetString
Gets a string from the specified start address.
- UINT
Address
Address of the first data byte
- BYTE
MaxLength
Maximum number of bytes in the string, also includes null termination byte
- STRING
SetByteArray
Writes an array of bytes to the EE memory.
- UINT
Address
Starting address of the first value to write
- BYTE
Data
- BYTE
Count
Number of bytes to write to the EE memory, Range: 1 to 128 bytes
SetInt
Writes a 16-bit value to the EE memory. For consecutive 16-bit values the address must be incremented by 2.
- UINT
Address
- UINT
Value
16-bit value to write
[[File:]] -
MSBFirst
0: LSB is the first byte, 1: MSB is the first byte
AddressSpecificDevice
Starts a temperature conversion on a specific device using a hex string identifier. SerialNumber parameter should be 12 characters and contain the 48-bit Serial.
- STRING
SerialNumber
48-bit Serial Number e.g. "32DF4A3C1901"
GetSerialString
Gets the Serial String for the current addressed device.
- STRING
AddressNextDevice
Scans for the next connected device with a matching family code. Goes through the device list generated by the ScanBus macro.
SetLong
Writes a 32-bit value to the EE memory. For consecutive 32-bit values the address must be incremented by 4.
- UINT
Address
- ULONG
Value
32-bit value to write
[[File:]] -
MSBFirst
GetFloat
Reads a 32-bit floating point value starting from the specified byte address. For consecutive float values the address must be incremented by 4.
[[File:]] -
Address
The starting byte address
[[File:]] -
MSBFirst
[[File:]] -
GetLong
Reads a 32-bit value starting from the specified byte address. For consecutive 32-bit values the address must be incremented by 4.
[[File:]] -
Address
[[File:]] -
MSBFirst
- ULONG
GetInt
Reads a 16-bit value starting from the specified byte address. For consecutive 16-bit values the address must be incremented by 2.
[[File:]] -
Address
[[File:]] -
MSBFirst
- UINT
GetByteArray
Reads an array of bytes starting from the selected address.
- UINT
Address
Starting address of the first value to read
- BYTE
Data
Byte array to store incoming data
- UINT
Count
Number of bytes to read from the EE memory, Range: 1 to 128 bytes
SetByte
Writes a single byte to the EE memory.
- UINT
Address
- BYTE
Data
GetByte
Reads a single byte from the selected address.
- UINT
Address
Address of the value to read
- BYTE
SetFloat
Writes a 32-bit floating point value to the EE memory. For consecutive float values the address must be incremented by 4.
- UINT
Address
[[File:]] -
Value
Floating point value to write
[[File:]] -
MSBFirst
Configures each matching sensor on the bus with the specified conversion bits.
SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
[[File:]] -
Value
[[File:]] -
MSBfirst
0=Least significant byte first, 1=Most significant byte first
GetProp
Allows the property filter for the COM port list to be copied to a parent component.
- STRING
PropName
- STRING
ReceiveByteArray
Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
- BYTE
Data
- UINT
MaxLength
Max number of bytes to try and read
- UINT
Timeout
Time to wait for incoming data in milliseconds
- UINT
ReceiveString
Attempts to receive an string using the COM port Returns the number of bytes received.
- UINT
Timeout
- UINT
MaxLength
- STRING
PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
- BYTE
EnableMask
Range 0-63 or 0b00000 to 0b111111
GetProp
- STRING
PropName
- STRING
One Wire Component
Link to the one wire component to host the bus.
EEPROM Size (Bytes)
Number EE Devices
Sens the number of sensors we can communicate with during simulation
Serial 0
Serial number for simulated one wire device
Simulations
Simulate Comms
No - We use the panel GUI to perform the simulation. Yes - We use OneWire comms via an API to communicate with real hardware.
