Component: String Initialiser (Storage)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.0 |
Category | Storage |
String Initialiser component
A component allowing an easy way to initialise string variables using ROM memory. A simple and efficient way to populate string variables helping to save on RAM usage. Allows up to 16 strings to be stored. For additional strings simply use more String Initialiser components.
GetString |
Gets a string stored in ROM memory and loads into a RAM string variable | |
Index |
Range: 0-15 Depending on number of strings | |
Return |
Initialise |
Initialises the SPI bus ready for communications. | |
Return |
Initialise |
Configures each matching sensor on the bus with the specified conversion bits. | |
Return |
GetProp |
Allows the property filter for the COM port list to be copied to a parent component. | |
PropName |
Return |
Initialise |
Return |
GetProp |
PropName |
Return |
Properties |
Number of Strings |
String 0 |
String data index 0 | |
String 1 |
String data index 1 | |
Connections |
Simulations |
