Component: ADC (MCP356X) (Analog Input)
Author | MatrixTSL |
Version | 1.0 |
Category | Analog Input |
ADC (MCP356X) component
An external ADC featuring 2, 4, or 8 channel 24-bit input. Capable of reading each channel independently or in differential mode. Communication using an SPI bus up to 20MHz.
Initialise |
Confgures the SPI bus ready for communications and initialises the MCP356X device. Returns true if device is responding to commands. | |
[[File:]] - | Return |
SendChar |
Transmits a byte value to the Zigbee module. | |
Byte |
Data byte to transmit. Range 0-255 | |
Return |
InitNetwork |
Initialises the Zigbee module and attempts to setup or join the network | |
Return |
ConnectToCoordinator |
Attempts to connect the data channel to the network coordinator node. | |
Return |
MIAC_Module_GetData |
Index |
Return |
ConnectToName |
Attempts to connect the data channel to a named device on the network. | |
Name |
Return |
StoreParams |
Stores the current register set into the Zigbee module's non volatile memory | |
Return |
EnterCommandMode |
Moves from data mode into command mode by sending the special characters | |
Return |
RestartNetwork |
Attempts to restart the network | |
Return |
MIAC_Module_Message |
CAN_ID |
CMD_ID |
Return |
ConnectToAll |
Attempts to connect the data channel to all devices on the network. | |
Return |
ConnectFromLibrary |
Attempts to connect the data channel to a known device on the network. | |
Mode |
Device |
Return |
ConnectToAddress |
Attempts to connect the data channel to a specific device address on the network. | |
Address |
Return |
GetSignalLevel |
Returns the signal strength of the last signal received | |
Return |
ExitCommandMode |
Returns from command mode to allow data to be sent and received | |
Return |
MIAC_Module_PushData |
Data |
Return |
ReadAddressFromBuffer |
Reads a byte from a 16-bit Zigbee device address | |
Device |
Idx |
Return |
SendATCommand |
Transmits a string of values to the Zigbee module. | |
Command |
Transmits a command to the Zigbee module followed by a carriage return | |
Return |
GetATResponse |
Waits for a response from the Zigbee module. If the Logging parameter is set then the response is stored in memory allowing the software to read the reply. | |
Logging |
Return |
ReceiveChar |
Attempt to receive a byte from the Zigbee module. | |
nTimeout |
Return |
ARB4 |
Loads the binary-data to an existing arbitrary waveform memory location ARB4. | |
Waveform |
Return |
CLKSRRet |
Returns the clock source <INT> or <EXT>. | |
MODPMDEV |
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°). | |
[[File:]] - | Degrees |
Sets PM waveform deviation in degrees (-360 - 360). | |
Return |
MSTLOCK |
Sends signal to SLAVE generator to get synchronised | |
Return |
HILVL |
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V). | |
[[File:]] - | HighLevel |
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V). | |
Return |
ARB3 |
Loads the binary-data to an existing arbitrary waveform memory location ARB3. | |
Waveform |
Return |
CALADJ |
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100). | |
[[File:]] - | Calibrate |
Adjust the selected calibration value (-100 - 100). | |
Return |
STBRet |
Returns the value of the Status Byte Register in <nr1> numeric format. | |
Return |
ARB2 |
Loads the binary-data to an existing arbitrary waveform memory location ARB2. | |
Waveform |
Return |
EERRet |
Query and clear execution error number register. | |
Return |
MODFMSRC |
Sets FM waveform source to; 0 INT, 1 = EXT. | |
[[File:]] - | Source |
Sets FM waveform source (0 = INT, 1 = EXT). | |
Return |
MODAMFREQ |
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
[[File:]] - | Frequency |
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
Return |
ESE |
Sets the Standard Event Status Enable Register to the value of <nrf>. | |
Value |
Value of register 0-255 | |
Return |
ARB1 |
Loads the binary-data to an existing arbitrary waveform memory location ARB1. | |
Waveform |
16 Bit binary number for arbitrary waveform. | |
Return |
ARB4DEFRet |
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4. | |
Return |
CLS |
Clears status byte register of the interface. | |
Return |
MSTRELOCK |
Resynchronises the two generators in MASTER-SLAVE mode. | |
Return |
NOISLVL |
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%) | |
Percent |
Sets the output noise level in percent. (0 - 50) | |
Return |
LOCKMODE |
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP. | |
Mode |
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP). | |
Return |
ADDRESSRet |
Returns the instruments address | |
MODPMSRC |
Sets PM waveform source to; 0 INT, 1 = EXT. | |
Sets PM waveform source (0 = INT, 1 = EXT). | |
Return |
MODPWMSRC |
Sets PWM waveform source to; 0 = INT, 1 = EXT. | |
Sets PWM waveform source (0 = INT, 1 = EXT). | |
Return |
MOD |
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM. | |
Modulation |
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM). | |
Return |
ISTRet |
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true. | |
LRNRet |
Returns the complete setup of the instrument as a binary data block | |
OPCRet |
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential. | |
PULSRANGE |
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3. | |
Range |
Sets the pulse rise and fall range. (1, 2 or 3) | |
Return |
TSTRet |
The generator has no self test capability and the response is always 0 <rmt>. | |
BSTTRGPOL |
Sets the burst trigger slope to; 0 = POS, 1 = NEG. | |
[[File:]] - | Slope |
Set the burst trigger slope (0 = POS, 1 = NEG). | |
Return |
ARB3Ret |
Returns the binary-data from an existing abbitrary wavefrom memory location. | |
Return |
BSTPHASE |
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360) | |
Sets the burst phase in degrees (-360 - 360) | |
Return |
SWPTRGPER |
Sets the sweep trigger period to <nrf> seconds | |
[[File:]] - | Seconds |
Set the sweep trigger period in seconds. | |
Return |
PULSDLY |
Sets the waveform delay to <nrf> sec | |
[[File:]] - | Sec |
Return |
Initialise |
Opens the COM port ready for communications. | |
Return |
