Component: GLCD Bitmap Drawer FAT (Graphical Library)
Revision as of 10:41, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.2
Category Graphical Library
GLCD Bitmap Drawer FAT component
A component to simplify the process of drawing bitmap images to a graphical display. Reads Bitmap files directly from a SD card formatted with a FAT file system. Compatible with 24-bit & Monochrome Bitmaps. The gLCD object property specifies which LCD component to draw the bitmap to. Compatible with GLCD, NeoPixel, MIACv3, HT16K33
The Bitmap Drawer FAT component must be linked to the graphical LCD using the gLCD Object property and to the FAT component using the FAT Object property.
Here is an example which loops drawing a monochrome and 24-bit bitmaps to the EBM001 graphical display.
FC6 Icon.png Bitmap Drawer FAT Demo
The bitmap files used in the example can be found here.
ZIP Icon.png Bitmap Drawer FAT Files
Fc9-comp-macro.png GetHeight
Returns the height of the loaded bitmap file in pixels.
The filename of the bitmap we want to measure
Fc9-comp-macro.png GetWidth
Returns the width of the loaded bitmap file in pixels.
Fc9-comp-macro.png SetTransparentColour
Sets the transparency colour, the colour that is not drawn when transparency is enabled.
Fc9-u8-icon.png - BYTE R
Fc9-u8-icon.png - BYTE G
Fc9-u8-icon.png - BYTE B
Fc9-comp-macro.png Display_BMP
Draws the bitmap image from ROM onto the display at the corrdinates X and Y. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
Bitmap file to open from current directory on SD card 8.3 format
Fc9-u16-icon.png - UINT X
X Axis coordinate, specifies the location of the left edge of the bitmap image
Fc9-u16-icon.png - UINT Y
Y Axis coordinate, specifies the location of the top edge of the bitmap image
0=Normal, 1=90 Degrees CW, 2=180 Degrees, 3=270 Degrees CW
Fc9-u8-icon.png - BYTE Transparency
0=Off, 1=On Don't Draw Any Pixels which match the transparent colour
Fc9-u8-icon.png - BYTE Flip
0=Normal, 1=FlipWidth, 2=FlipHeight, 3=FlipBoth
Fc9-comp-macro.png Display_BMP_Fast
Draws the bitmap image from ROM onto the display at the corrdinates X and Y. Attempts to draw a row at a time by not forcing coordinates for every pixel so may not work on some displays. Return Values: 0=OK, 1=ColourDepthNotSupported, 237=FileNotFound
Draws the bitmap image from ROM onto the display at the corrdinates X and Y. Attempts to draw a row at a time by not forcing coordinates for every pixel so may not work on some displays. Currently only supports colour displays.
Fc9-u8-icon.png - BYTE BitmapIndex
Selects from attached bitmaps. Range: 0-9
Fc9-comp-macro.png ShowName
Sets the label to show the target object's name
Fc9-comp-macro.png RawEnable
Enables and configures the ADC channel to be an analogue input. Only one ADC channel can be enabled at a time. Any RAW functions will reference the last enabled channel only.
Fc9-comp-macro.png SetChannel
Sets the channel ID for the component
[[File:]] - ChannelId
Chaannel starting at 0, -1 is unconnected
Fc9-comp-macro.png RawSampleByte
Background call to read the ADC as a byte Call Enable() before this
Fc9-comp-macro.png GetInt
Blocking call to read the ADC at full bit depth
Fc9-comp-macro.png RawDisable
Disables the previously enabled ADC channel and converts back to digital mode.
Fc9-comp-macro.png GetByte
Blocking call to read the ADC as a byte
Fc9-comp-macro.png ConnectToAddress
Attempts to connect the data channel to a specific device address on the network.
Fc9-string-icon.png - STRING Address
Fc9-comp-macro.png GetSignalLevel
Returns the signal strength of the last signal received
Fc9-comp-macro.png ExitCommandMode
Returns from command mode to allow data to be sent and received
Fc9-comp-macro.png MIAC_Module_PushData
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png ReadAddressFromBuffer
Reads a byte from a 16-bit Zigbee device address
Fc9-u8-icon.png - BYTE Device
Fc9-u8-icon.png - BYTE Idx
Fc9-comp-macro.png SendATCommand
Transmits a string of values to the Zigbee module.
Fc9-string-icon.png - STRING Command
Transmits a command to the Zigbee module followed by a carriage return
Fc9-comp-macro.png ScanNetwork
Scans the local network for devices and stores into a local device array. Mode = 0 store device names, mode = 1 store device addresses. Returns the number of devices found.
Fc9-u8-icon.png - BYTE Mode
Fc9-comp-macro.png GetATResponse
Waits for a response from the Zigbee module. If the Logging parameter is set then the response is stored in memory allowing the software to read the reply.
Fc9-u8-icon.png - BYTE Logging
Fc9-comp-macro.png ReceiveChar
Attempt to receive a byte from the Zigbee module.
Fc9-u8-icon.png - BYTE nTimeout
Fc9-comp-macro.png MODPMSHAPE
Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
Fc9-u8-icon.png - BYTE Shape
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
Fc9-comp-macro.png ARB4
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
Fc9-u8-icon.png - BYTE Waveform
Fc9-comp-macro.png CLKSRRet
Returns the clock source <INT> or <EXT>.
[[File:]] - Return
Fc9-comp-macro.png MODPMDEV
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
[[File:]] - Degrees
Sets PM waveform deviation in degrees (-360 - 360).
Fc9-comp-macro.png MSTLOCK
Sends signal to SLAVE generator to get synchronised
Fc9-comp-macro.png HILVL
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
[[File:]] - HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
Fc9-comp-macro.png ARB3
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
Fc9-u16-icon.png - UINT Waveform
Fc9-comp-macro.png WAVE
Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
Fc9-u8-icon.png - BYTE WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
Fc9-comp-macro.png CALADJ
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
[[File:]] - Calibrate
Adjust the selected calibration value (-100 - 100).
Fc9-comp-macro.png STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
Fc9-comp-macro.png ARB2
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
Fc9-comp-macro.png EERRet
Query and clear execution error number register.
Fc9-comp-macro.png MODFMSRC
Sets FM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets FM waveform source (0 = INT, 1 = EXT).
Fc9-comp-macro.png MODAMFREQ
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
[[File:]] - Frequency
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
Fc9-comp-macro.png ESE
Sets the Standard Event Status Enable Register to the value of <nrf>.
Fc9-u8-icon.png - BYTE Value
Value of register 0-255
Fc9-comp-macro.png ARB1
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
16 Bit binary number for arbitrary waveform.
Fc9-comp-macro.png ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
Fc9-comp-macro.png CLS
Clears status byte register of the interface.
Fc9-comp-macro.png MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
Fc9-comp-macro.png NOISLVL
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
Fc9-u8-icon.png - BYTE Percent
Sets the output noise level in percent. (0 - 50)
Fc9-comp-macro.png LOCKMODE
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
Fc9-comp-macro.png ADDRESSRet
Returns the instruments address
[[File:]] - Return
Fc9-comp-macro.png MODPMSRC
Sets PM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets PM waveform source (0 = INT, 1 = EXT).
Fc9-comp-macro.png MODPWMSRC
Sets PWM waveform source to; 0 = INT, 1 = EXT.
[[File:]] - Source
Sets PWM waveform source (0 = INT, 1 = EXT).
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
Fc9-u8-icon.png - BYTE Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
Fc9-comp-macro.png ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
[[File:]] - Return
Fc9-comp-macro.png LRNRet
Returns the complete setup of the instrument as a binary data block
[[File:]] - Return
Fc9-comp-macro.png OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
[[File:]] - Return
Fc9-comp-macro.png SWPTYPE
Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
Fc9-u8-icon.png - BYTE Type
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
Fc9-comp-macro.png PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
Fc9-u8-icon.png - BYTE Range
Sets the pulse rise and fall range. (1, 2 or 3)
Fc9-comp-macro.png TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
[[File:]] - Return
Fc9-comp-macro.png BSTTRGPOL
Sets the burst trigger slope to; 0 = POS, 1 = NEG.
[[File:]] - Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
Fc9-comp-macro.png ARB3Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
Fc9-comp-macro.png BSTPHASE
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
[[File:]] - Degrees
Sets the burst phase in degrees (-360 - 360)
Fc9-comp-macro.png IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
Fc9-string-icon.png - STRING ReturnIDN
Fc9-comp-macro.png SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
[[File:]] - Seconds
Set the sweep trigger period in seconds.
Fc9-comp-macro.png PULSDLY
Sets the waveform delay to <nrf> sec
[[File:]] - Sec
Fc9-type-17-icon.png FAT Object
FAT / SD Card Object to read the bitmap image from
Fc9-type-17-icon.png gLCD Object
Graphical LCD Object to draw the bitmap image to
Fc9-type-7-icon.png ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
Fc9-conn-icon.png Simulations
