Component: GLCD (EBM001) (EBM Modules)
Revision as of 10:42, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.6
Category EBM Modules
GLCD (EBM001) component
Graphical display component designed to work with the EBM001 modules and EB084 E-blocks. Based on the ILI9163C 16-bit colour graphical controller IC.
EBM001 Basic Example
EBM001 gLCD Example File FC6 Icon.png EBM001 Example Example should show the following on the display on the panel and on the hardware.
EBM001 Maze Builder
FC6 Icon.png Maze Builder gLCD Example to draw a randomly generated 2D maze on an EBM001 graphical display.
FC6 Icon.png 3D Manipulations Example should show the following on the display on the panel and on the hardware. The two switches allow you to move closer to or away from the object. The perspective provides more and more distortion to the object the closer you get.
Fc9-u8-icon.png - BYTE Font
Fc9-comp-macro.png BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
Fc9-u8-icon.png - BYTE ScaleX
Fc9-u8-icon.png - BYTE ScaleY
[[File:]] - Number
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-comp-macro.png DrawLine
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-comp-macro.png Plot
Fc9-u8-icon.png - BYTE Solid
Fc9-comp-macro.png FastPlot
Fc9-comp-macro.png BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
Fc9-comp-macro.png BPlot
Fc9-comp-macro.png Window
Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
Fc9-u8-icon.png - BYTE Index
0=SpaceWidth, 1=PixelHeight
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-comp-macro.png DrawCircle
Fc9-comp-macro.png Initialise
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
Fc9-comp-macro.png MODPMSHAPE
Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
Fc9-u8-icon.png - BYTE Shape
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
Fc9-comp-macro.png ARB4
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
Fc9-u8-icon.png - BYTE Waveform
Fc9-comp-macro.png CLKSRRet
Returns the clock source <INT> or <EXT>.
[[File:]] - Return
Fc9-comp-macro.png MODPMDEV
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
[[File:]] - Degrees
Sets PM waveform deviation in degrees (-360 - 360).
Fc9-comp-macro.png MSTLOCK
Sends signal to SLAVE generator to get synchronised
Fc9-comp-macro.png HILVL
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
[[File:]] - HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
Fc9-comp-macro.png ARB3
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
Fc9-u16-icon.png - UINT Waveform
Fc9-comp-macro.png WAVE
Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
Fc9-u8-icon.png - BYTE WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
Fc9-comp-macro.png CALADJ
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
[[File:]] - Calibrate
Adjust the selected calibration value (-100 - 100).
Fc9-comp-macro.png STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
Fc9-comp-macro.png ARB2
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
Fc9-comp-macro.png EERRet
Query and clear execution error number register.
Fc9-comp-macro.png MODFMSRC
Sets FM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets FM waveform source (0 = INT, 1 = EXT).
Fc9-comp-macro.png MODAMFREQ
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
[[File:]] - Frequency
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
Fc9-comp-macro.png ESE
Sets the Standard Event Status Enable Register to the value of <nrf>.
Fc9-u8-icon.png - BYTE Value
Value of register 0-255
Fc9-comp-macro.png ARB1
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
16 Bit binary number for arbitrary waveform.
Fc9-comp-macro.png ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
Fc9-comp-macro.png CLS
Clears status byte register of the interface.
Fc9-comp-macro.png MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
Fc9-comp-macro.png NOISLVL
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
Fc9-u8-icon.png - BYTE Percent
Sets the output noise level in percent. (0 - 50)
Fc9-comp-macro.png LOCKMODE
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
Fc9-u8-icon.png - BYTE Mode
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
Fc9-comp-macro.png ADDRESSRet
Returns the instruments address
[[File:]] - Return
Fc9-comp-macro.png MODPMSRC
Sets PM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets PM waveform source (0 = INT, 1 = EXT).
Fc9-comp-macro.png MODPWMSRC
Sets PWM waveform source to; 0 = INT, 1 = EXT.
[[File:]] - Source
Sets PWM waveform source (0 = INT, 1 = EXT).
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
Fc9-u8-icon.png - BYTE Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
Fc9-comp-macro.png ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
[[File:]] - Return
Fc9-comp-macro.png LRNRet
Returns the complete setup of the instrument as a binary data block
[[File:]] - Return
Fc9-comp-macro.png OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
[[File:]] - Return
Fc9-comp-macro.png SWPTYPE
Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
Fc9-u8-icon.png - BYTE Type
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
Fc9-comp-macro.png PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
Fc9-u8-icon.png - BYTE Range
Sets the pulse rise and fall range. (1, 2 or 3)
Fc9-comp-macro.png TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
[[File:]] - Return
Fc9-comp-macro.png BSTTRGPOL
Sets the burst trigger slope to; 0 = POS, 1 = NEG.
[[File:]] - Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
Fc9-comp-macro.png ARB3Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
Fc9-comp-macro.png BSTPHASE
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
[[File:]] - Degrees
Sets the burst phase in degrees (-360 - 360)
Fc9-comp-macro.png IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
Fc9-string-icon.png - STRING ReturnIDN
Fc9-comp-macro.png SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
[[File:]] - Seconds
Set the sweep trigger period in seconds.
Fc9-comp-macro.png PULSDLY
Sets the waveform delay to <nrf> sec
[[File:]] - Sec
Opens the COM port ready for communications.
Fc9-type-14-icon.png Colour Bit Depth
Fc9-type-16-icon.png Display Method
Fc9-type-5-icon.png Data
Data pin connection
Fc9-type-5-icon.png Clock
Clock pin connection
Fc9-type-5-icon.png Chip Select
Chip select pin connection
Fc9-type-5-icon.png A0
Fc9-type-5-icon.png Reset
Reset pin connection
Fc9-type-5-icon.png LED
Fc9-conn-icon.png Simulations
