Author
Matrix Ltd
Version
1.4
Category
Graphical Monochrome
GLCD (ST7920) Parallel component
Graphical display component designed to work with the ST7920 ype monochrome displays. Transfers data using an 8-bit digital data bus.
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
[[File:]] -
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Write_Data
- BYTE
data
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
SetDisplayOrientation
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
Write_Command
- BYTE
Command
SetForegroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
MODPMSHAPE
Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE
Shape
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
ARB4
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
- BYTE
Waveform
CLKSRRet
Returns the clock source <INT> or <EXT>.
[[File:]] -
MODPMDEV
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
[[File:]] -
Degrees
Sets PM waveform deviation in degrees (-360 - 360).
MSTLOCK
Sends signal to SLAVE generator to get synchronised
HILVL
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
[[File:]] -
HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
ARB3
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
- UINT
Waveform
WAVE
Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
- BYTE
WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
CALADJ
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
[[File:]] -
Calibrate
Adjust the selected calibration value (-100 - 100).
STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
- BYTE
ARB2
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
- UINT
Waveform
EERRet
Query and clear execution error number register.
- STRING
MODFMSRC
Sets FM waveform source to; 0 INT, 1 = EXT.
[[File:]] -
Source
Sets FM waveform source (0 = INT, 1 = EXT).
MODAMFREQ
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
[[File:]] -
Frequency
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
ESE
Sets the Standard Event Status Enable Register to the value of <nrf>.
- BYTE
Value
Value of register 0-255
ARB1
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
- UINT
Waveform
16 Bit binary number for arbitrary waveform.
ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
- STRING
CLS
Clears status byte register of the interface.
MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
NOISLVL
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
- BYTE
Percent
Sets the output noise level in percent. (0 - 50)
LOCKMODE
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
- BYTE
Mode
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
ADDRESSRet
Returns the instruments address
[[File:]] -
MODPMSRC
Sets PM waveform source to; 0 INT, 1 = EXT.
[[File:]] -
Source
Sets PM waveform source (0 = INT, 1 = EXT).
MODPWMSRC
Sets PWM waveform source to; 0 = INT, 1 = EXT.
[[File:]] -
Source
Sets PWM waveform source (0 = INT, 1 = EXT).
MOD
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
- BYTE
Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
[[File:]] -
LRNRet
Returns the complete setup of the instrument as a binary data block
[[File:]] -
OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
[[File:]] -
SWPTYPE
Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
- BYTE
Type
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
- BYTE
Range
Sets the pulse rise and fall range. (1, 2 or 3)
TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
[[File:]] -
BSTTRGPOL
Sets the burst trigger slope to; 0 = POS, 1 = NEG.
[[File:]] -
Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
ARB3Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
- UINT
BSTPHASE
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
[[File:]] -
Degrees
Sets the burst phase in degrees (-360 - 360)
IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
- STRING
ReturnIDN
- STRING
SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
[[File:]] -
Seconds
Set the sweep trigger period in seconds.
PULSDLY
Sets the waveform delay to <nrf> sec
[[File:]] -
Sec
Opens the COM port ready for communications.
Pixel Width
Pixel Height
Monochrome
Foreground Color
Background Color
Color Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Data Mode
Data0
Data Pin 0
Data1
Data Pin 1
Data2
Data Pin 2
Data3
Data Pin 3
Data4
Data Pin 4
Data5
Data Pin 5
Data6
Data Pin 6
Data7
Data Pin 7
Reset
Reset pin
RS
Enable
Enable pin used to clock data into the display
RW
Read Write pin to set the display data mode
Simulations
