Component: I2S Master/Slave ESP32 (Comms: Interface)
Revision as of 11:01, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category Comms: Interface
I2S Master/Slave ESP32 component
Provides access to the onboard inter-IC sound (I2S) peripheras allowing for simple digital audio input and output.
Fc9-comp-macro.png Stop
Stops the I2S audio stream
Fc9-comp-macro.png Read
Wait timeout ticks to receive length number of samples, returns samples received. 24 and 32-bit data must be split into two integer values per sample.
[[File:]] - Data
Data array to populate with incoming data
Max number of samples to try and receive
Fc9-u16-icon.png - UINT Timeout
Max number of ticks to wait for incoming samples
Fc9-comp-macro.png CheckQueue
Checks the I2S Event queue for a DMA Buffer full or empty event. For an output returns true when there is an empty DMA buffer available. For an input return true when there is a full DMA buffer available.
[[File:]] - Return
Fc9-comp-macro.png Write
Wait timeout ticks to send length number of samples, returns samples sent 24 and 32-bit data must be split into two integer values per sample.
[[File:]] - Data
Data array containing outgoing data
Max number of samples to try and send
Max number of ticks to wait for space in the outgoing buffer
Fc9-comp-macro.png Start
Starts the I2S audio stream, auto started by the initialise function.
Fc9-comp-macro.png Initialise
Configures the I2C peripheral ready for data.
Fc9-type-16-icon.png Channel
DAC Channel number
Fc9-type-5-icon.png Clock Pin
I2S Clock Pin
Fc9-type-5-icon.png Serial Data Pin
I2S Serial Data (SD) Pin
Fc9-type-5-icon.png Word Select Pin
I2S Word Select (WS) Pin
Fc9-type-16-icon.png Mode
Configures if the I2S peripheral is a master or slave on the bus.
Fc9-type-16-icon.png Data Direction
Controls if the I2S data is coming in or out of the microcontroller
Fc9-type-16-icon.png Audio Channels
Number of distinct audio channels in the data stream
Fc9-type-21-icon.png Sample Rate
Audio sample rate in Hz
Fc9-type-16-icon.png Data Bits
Nmber of bits in each audio sample
Fc9-type-21-icon.png DMA Buffer Count
I2S DMA Buffer Count
Fc9-type-21-icon.png DMA Buffer Size
I2S DMA Buffer Size
Fc9-conn-icon.png Simulations
