Component: UART Software (Timer) (Comms: Interface)
Jump to navigationJump to searchAuthor | MatrixTSL |
Version | 1.0 |
Category | Comms: Interface |
UART Software (Timer) component
Creates a reliable software UART that can be driven using a timer interrupt setup by the user. The timer interrupt must be interrupting at the required baud rate. e.g 9600Hz.
Simple example showing how to enable a timer interrupt at the desired baud rate then receive a string. If anything is received then it will be echoed back out and displayed on a LCD
SendString |
Sends an string to the transmit buffer | |
Data |
Return |
ReceiveArray |
Gets an array of values from the receive buffer. Returns number of values received. | |
Values |
NumValues |
Timeout |
Time in milliseconds to wait for data | |
Return |
SendArray |
Sends an array of values to the transmit buffer | |
Values |
NumValues |
Return |
UART_Timer_Process |
Called as part of a timer interrupt at the specific UART baud rate. | |
Return |
ReceiveValue |
Gets a single value from the receive buffer | |
Timeout |
Return |
SendValue |
Sends a single value to the transmit buffer | |
Value |
Return |
CheckBuffer |
Returns the number of values in the transmit or receive buffer | |
[[File:]] - | Buffer |
0=Transmit / 1=Receive | |
Return |
ReceiveString |
Gets a string from the receive buffer | |
MaxChars |
Timeout |
Return |
Initialise |
Initialises the UART component pins ready to send and receive data | |
Return |
