Component: Offset (DSP)
Revision as of 11:03, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.1
Category DSP
Offset component
Allows the values in a single buffer to be offset uniformly. Functions include: Add, Subtract
Fc9-comp-macro.png Calculate
Performs the selected offset on a value from the input buffer and passes to the output buffer.
Fc9-comp-macro.png CalculateArray
Performs the selected offset on an entire buffer.
Fc9-comp-macro.png SetOffset
Sets the Offset to be used when calling the calculate function.
[[File:]] - Offset
Fc9-type-17-icon.png Connect To
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type.
Fc9-type-16-icon.png Offset Type
Defines the type of calculation performed on the input buffer to obtain the output value. A left shift is essentially an optimised multiply with the multiplier being the 2^scaler A right shift is essentially an optimised divide with the divider being the 2^scaler
Fc9-type-7-icon.png Rollover
Allow the output buffer to rollover. For example 128 + 128 = 256 which would equate to 0 using an 8-bit buffer with rollover enabled. With rollover disabled the output would be set to 255 which is the max representable value.
Fc9-type-14-icon.png Initial Offset
Fc9-conn-icon.png Simulations
