Component: Temp / Humidity (Grove 101020212) (101020212) (Environmental)
Revision as of 11:03, 17 November 2021 by Wiki bot (talk | contribs)
Version 2.0
Category Environmental
Temp / Humidity (Grove 101020212) component
Humidity and temperature sensor using an SHT31 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
Fc9-comp-macro.png GetTemperatureReal
Return temperature reading as a float value in degrees C
[[File:]] - Return
Fc9-comp-macro.png GetTemperatureData
Returns the raw register pair value
Fc9-comp-macro.png GetTemperatureInt
Return temperature reading as an integer value in degrees C
[[File:]] - Return
Fc9-comp-macro.png GetHumidityInt
returns the relative Humidity reading as an integer value
[[File:]] - Return
Fc9-comp-macro.png GetHumidityReal
returns the Humidity reading as a float value
[[File:]] - Return
Fc9-comp-macro.png GetHumidityData
Fc9-comp-macro.png Initialise
Configures the I2C peripheral and puts the sensor into one shot mode ready to be sampled. Must be called before calling any of the other component macros. Returns 1 if the sensor has been intialised correctly, else returns 0.
Fc9-type-16-icon.png Address
Selects the correct device address based on the ADDR pin connection to VDD or VSS.
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-type-16-icon.png API
Fc9-conn-icon.png Simulations
Fc9-type-7-icon.png Simulation Comms
