Component: IO Expander (PCF8574) (Comms: System)
Revision as of 11:04, 17 November 2021 by Wiki bot (talk | contribs)
Category Comms: System
IO Expander component
Provides 8 digital input/output pins arranged into an 8-bit port using a I2C bus connection. Up to eight expanders can be connected to the same I2C peripheral by means of three address pins. Supports the PCF8574 and PCF8574A devices allowing up to 16 expanders to be connected to the same I2C bus ( 8 x PCF8574 + 8 x PCF8574A ).
Fc9-comp-macro.png ReadPort
Reads the value of the IO pins.
Fc9-comp-macro.png WritePort
Writes a value to the IO pins.
Fc9-u8-icon.png - BYTE Value
Value to write. Range 0-255
Fc9-comp-macro.png Initialise
Fc9-type-16-icon.png Device Type
Fc9-type-16-icon.png External Address
Selects the value of the three address pins for the MCP23S17.
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulations
Fc9-type-10-icon.png Label
Fc9-type-16-icon.png API
