Component: Map Function (Storage)
Revision as of 11:05, 17 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | medelec35 |- | width="20%" style="color:gray;" | Version | 2.0 |- | width="20%" style="color:gray;...")
Author medelec35
Version 2.0
Category Storage
Map Function component
The map function is intended to change one range of values into another range of values. For example. Output from a temperature sensor is in centigrade. you can map it to give the result in Fahrenheit. To do that set: InMin to 0, InMax 100, OutMin to 32 & OutMax to 212
Fc9-comp-macro.png MapUlong
Map function for unsigned long type variables
Fc9-u32-icon.png - ULONG Value
Main variable used for map function
Fc9-u32-icon.png - ULONG InMin
Lowest input value
Fc9-u32-icon.png - ULONG InMax
Highest value input
Fc9-u32-icon.png - ULONG OutMin
Lowest value after conversion
Fc9-u32-icon.png - ULONG OutMax
highest value after conversion
[[File:]] - ClampMinMax
Clamp min & max so result does not go above or below set values. 0=No, 1=Yes
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png MapInt
Map function for signed int type variables
[[File:]] - Value
[[File:]] - InMin
Lowest input value
[[File:]] - InMax
Highest value input
[[File:]] - OutMin
[[File:]] - OutMax
[[File:]] - Return
Fc9-comp-macro.png MapFloat
Map function for floating point type variables
[[File:]] - Value
[[File:]] - InMin
Lowest input value
[[File:]] - InMax
Highest value input
[[File:]] - OutMin
[[File:]] - OutMax
[[File:]] - Return
Fc9-comp-macro.png MapLong
Map function for signed long type variables
[[File:]] - Value
[[File:]] - InMin
Lowest input value
[[File:]] - InMax
Highest value input
[[File:]] - OutMin
[[File:]] - OutMax
[[File:]] - Return
Fc9-comp-macro.png MapUInt
Map function for unsigned int type variables
Fc9-u16-icon.png - UINT Value
Fc9-u16-icon.png - UINT InMin
Lowest input value
Fc9-u16-icon.png - UINT InMax
Highest value input
Fc9-u16-icon.png - UINT OutMin
Fc9-u16-icon.png - UINT OutMax
Fc9-comp-macro.png MapByte
Map function for byte type variables
Fc9-u8-icon.png - BYTE Value
Fc9-u8-icon.png - BYTE InMin
Lowest input value
Fc9-u8-icon.png - BYTE InMax
Highest value input
Fc9-u8-icon.png - BYTE OutMin
Fc9-u8-icon.png - BYTE OutMax
Fc9-conn-icon.png Simulations
