Component: Accelerometer 3 Axis (LIS3LV02DQ) (Movement & Orientation)
Revision as of 11:06, 17 November 2021 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Movement & Orientation
Accelerometer 3-Axis component
LIS3LV02DQ Accelerometer sensor with options for I2C or SPI communications. Useful for approximating Pitch and Roll or for detecting acceleration. Also available in the form of the EB068 Accelerometer E-block.
Fc9-comp-macro.png SimReset1G
Resets the simulation to 0.0 on X and Y and 1.0 on Z as if the accelerometer was sitting completely horizontal.
Fc9-comp-macro.png Write_Register
Writes a data value to a specific register on the accelerometer
Fc9-u8-icon.png - BYTE Reg
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
Fc9-u8-icon.png - BYTE Axis
[[File:]] - Return
Fc9-comp-macro.png UpdateXYZData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
Fc9-comp-macro.png SimSetXYZ
Allows the XYZ slider values to be set via the simulation
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
Fc9-comp-macro.png Initialise
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
The number of binary bits used to store the sensor's X,Y,Z readings.
Fc9-type-16-icon.png Bus Type
The interface used to talk to the accelerometer. I2C - Two Wire Interface SDA / SCL SPI - Four Wire Interface MISO / MOSI / SCK / CS
Fc9-type-16-icon.png Data Rate
Configures how often the sensor collects a new reading. More often = better instant reaction to new events Less often = more stable results
Fc9-type-16-icon.png Scale
The accelerometer readings are scaled based on the maximum amount of G force the sensor can represent. 6G = Bigger gravitational force 2G = Higher resolution
Fc9-type-16-icon.png Int Option
Sets if we use the interrupt pin to check if new data is available
Fc9-type-16-icon.png Power Option
Sets if the sensor is always powered or powered via a microcontroller output pin.
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-type-16-icon.png API
Fc9-conn-icon.png Simulations
Fc9-type-7-icon.png Simulation Coms
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the CAL component - I2C or SPI - API etc
