Component: Thermistor (EBM003) (EBM Modules)
Revision as of 11:06, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.1
Category EBM Modules
Thermistor component
A generic thermistor component that can be used to simulate and create code for any thermistor with a known temperature/resistance curve. Thermistor is connected in a simple potential divider circuit - thermistor between ADC input and 0V, and a fixed resistor between ADC and the positive supply. The component is also used with the EBM003 module, in which case the extra circuitry is already included. Default calibration is for the EBM003 module.
Fc9-comp-macro.png GetIntegerTemperature
Reads the ADC input and returns the calculated Temperature as Integer degrees C
[[File:]] - Return
Fc9-comp-macro.png SetChannel
Set the ADC Channel
[[File:]] - ChannelID
Fc9-comp-macro.png GetRealTemperature
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C
[[File:]] - Return
Fc9-comp-macro.png SetTemperature
Sends the given temperature to the display, and calculates the internal values used by the simulated read macros.
[[File:]] - Temperature
Zero to one value - representing min-max of the sensor.
Fc9-comp-macro.png CalculateTemperature
Converts the input ADC value and returns the Temperature in tenths of degree C
Fc9-u16-icon.png - UINT ADCValue
ADC Reading to be converted
[[File:]] - Return
Fc9-comp-macro.png GetADCValue
Returns the Raw ADC value from the Analogue Channel
Fc9-type-6-icon.png ADC Channel
The ADC channel to which the thermistor circuit is connected. It is assumed that the thermistor is connected between the ADC pin and 0V, with a fixed resistor connected between the ADC pin and +V.
Fc9-type-16-icon.png Wiring
Specifies the arrangement of the Thermistor and Fixed Resistor. Pull Down - Thermistor connected between ADC pin and GND, fixed resistor between ADC pin and VCC. Pull Up - Thermistor connected between ADC pin and VCC, fixed resistor between ADC pin and GND.
Fc9-type-21-icon.png ADC Bit Resolution
Fc9-type-21-icon.png Resistor Value
Value in Ohms of the pullup series resistor. i.e. The resistor is connected between the ADC pin and the positive supply rail.
Fc9-type-21-icon.png -25C Thermistor Value
Value in Ohms of the Thermistor at -25 deg C
Fc9-type-21-icon.png 0C Thermistor Value
Value in Ohms of the Thermistor at 0 deg C
Fc9-type-21-icon.png 25C Thermistor Value
Value in Ohms of the Thermistor at 25 deg C
Fc9-type-21-icon.png 50C Thermistor Value
Value in Ohms of the Thermistor at 50 deg C
Fc9-type-21-icon.png 75C Thermistor Value
Value in Ohms of the Thermistor at 75 deg C
Fc9-type-21-icon.png 100C Thermistor Value
Value in Ohms of the Thermistor at 100 deg C
Fc9-type-21-icon.png 125C Thermistor Value
Value in Ohms of the Thermistor at 125 deg C
Fc9-conn-icon.png Simulations
Fc9-type-10-icon.png Label
A text label to help you identify the component on the panel.
