Component: Serial EEPROM (24C32) (Storage)
Revision as of 11:07, 17 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 2.2 |- | width="20%" style="color:gray...")
Version 2.2
Category Storage
Serial EEPROM (24C32) component
Serial (I2C) EEPROM component for 24C32 Can be added to a MIAC project to give read and write access to the internal non-volatile memory device (if fitted, depending upon model).
Fc9-comp-macro.png Read
Read and return the value of the EEPROM at the given address
Fc9-u16-icon.png - UINT address
Fc9-comp-macro.png Write
Write the given data value to the EEPROM at the given address
Fc9-u8-icon.png - BYTE data
Fc9-type-16-icon.png Device Address
Device address bits, these must match the address pins on the EEPROM IC.
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulations
Fc9-type-16-icon.png API
