Component: PIC32 Core Timer (Storage)
Revision as of 11:08, 17 November 2021 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Storage
PIC32 Core Timer component
Allows for easy and accurate timings using the built in Core timer on the PIC32 devices.
Fc9-comp-macro.png Start_S
A none blocking function that allows for accurate delays to be specified in seconds using the core timer.
Fc9-u32-icon.png - ULONG Delay
Fc9-comp-macro.png Start_InstructionCount
A none blocking function that allows for accurate delays to be specified in FOSC instructions using the core timer.
Fc9-comp-macro.png Delay_S
A blocking function that allows for accurate delays to be specified in seconds using the core timer.
Fc9-comp-macro.png Start_Ms
A none blocking function that allows for accurate delays to be specified in milliseconds using the core timer.
Fc9-comp-macro.png Start_Us
A none blocking function that allows for accurate delays to be specified in micro seconds using the core timer.
Fc9-comp-macro.png Delay_Ms
A blocking function that allows for accurate delays to be specified in milliseconds using the core timer.
Fc9-comp-macro.png Delay_InstructionCount
A blocking function that allows for accurate delays to be specified in FOSC instructions using the core timer.
Fc9-comp-macro.png Start_Ns
A none blocking function that allows for accurate delays to be specified in nano seconds using the core timer.
Fc9-comp-macro.png Delay_Us
A blocking function that allows for accurate delays to be specified in micro seconds using the core timer.
Fc9-comp-macro.png Delay_Ns
A blocking function that allows for accurate delays to be specified in nano seconds using the core timer.
Fc9-comp-macro.png Check_Counter
Checks to see if the counter time is elapsed. Used in conjunction with the Start_ component macros. Returns 1 if complete or 0 if still counting.
[[File:]] - Return
Fc9-conn-icon.png Simulations
