Component: ADC QUAD + DAC (PCF8591) (Analog Input)
Revision as of 11:08, 17 November 2021 by Wiki bot (talk | contribs)
Category Analog Input
ADC QUAD + DAC (PCF8591) component
An I2C device allowing for up to 4 x 8-bit analogue inputs as well as 1 x 8-bit analogue output. Up to 8 devices can be used together ona signel I2C bus.
Fc9-comp-macro.png EnableDAC
Enables and Disables the DAC output, Default Disabled.
[[File:]] - Enabled
0=Disabled, 1=Enabled
Fc9-comp-macro.png WriteDAC
Writes a value to the digital to analogue output.
Fc9-u8-icon.png - BYTE Value
Fc9-comp-macro.png SetupADC
Configures how the ADC inputs are wired
Fc9-u8-icon.png - BYTE Configuration
Range: 0-3, Default 0
Fc9-comp-macro.png SampleADC
Performs a single ADC sample on the selected ADC channel
Range: 0-3
Fc9-comp-macro.png Initialise
Sets up the I2C bus ready for communications with the device.
Fc9-type-16-icon.png API
Fc9-type-16-icon.png Device Address
The address pins are used to allow up to 8 individual devices to be connected onto an I2C bus. Sets the state of the pins.
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulations
Allows the communications to be simulated overriding the value on the panel slider controls.
