Author
Matrix Ltd
Version
2.0
Category
E-blocks 1
GLCD (EB076) component
Graphical display component designed to work with the Picaso range of displays from 4D Systems. Also available in the form of the EB076 GLCD Touchscreen E-block. Component based around the uLCD-32PT display.
G4D_InitialiseCard
Initialises the micro SD card inserted into the module is available. Returns 0 for succesful initialisation or 255 for a detected failure.
- BYTE
G4D_DumpScreenToFilePicaso
Copies a section of the display to the micro SD card starting from X, Y and ranging to Width, Height.
- UINT
X
- UINT
Y
- UINT
Width
- UINT
Height
- STRING
Filename
Assigns the name of the file on the card to store the data.
- BYTE
G4D_ReadTouchCoordinatesPicaso
Returns the coordinates of the last touch event. Axis = 0 or 'x' or 'X' - Returns the X coordinate. Axis = 1 or 'y' or 'Y' - Returns the Y coordinate.
- BYTE
Axis
- UINT
G4D_GetTouchCoordinatesPicaso
Reads the value of the last touchscreen input from the display. Returns a 0 if no new touch is detected. Returns a 1 if a press is detected. Returns a 2 if a release is detected. Returns a 3 if a moving drag is detected.
- BYTE
[[File:]] -
Number
- UINT
X
- UINT
Y
- BYTE
Font
Size of the font - 0 = Normal, 1 = Double Width, 2 = Double Width and Height, 3 = Double Height
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
G4D_DisplayImageFromFilePicaso
Attempts to print an image from the micro SD card using the specified filename on the card. The image is printed at location starting from X, Y. PosH and PosL specify the sector address of the previously stored image icon.
- UINT
X
- UINT
Y
- STRING
Filename
- UINT
PosH
- UINT
PosL
- BYTE
G4D_DisableTouchscreenPicaso
Disables the touchscreen interface if available.
- BYTE
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
DisplayControl
Controls the operation, contrast and backlight on the display
- BYTE
Backlight
0=Backlight Off, 1=Backlight On (default)
- BYTE
Display
0=Display off, 1=Display on (default)
- BYTE
Contrast
Contrast Range 0 - 15
FastPlot
G4D_EnableTouchscreenPicaso
Enables the touchscreen interface if available.
- BYTE
G4D_DisplayVideoFromCard
Attempts to display a sequence of images from the micro SD card at the specified address location on the card. The images are printed at location starting from X, Y and ranging to Width, Height.
- UINT
X
- UINT
Y
- UINT
Width
- UINT
Height
- BYTE
ColourMode
Specifes the colour depth setting - 0 = 8-bit colour, 1 = 16-bit colour.
- BYTE
Delay
Specifies the number of milliseconds to wait in between displaying each image.
- UINT
Frames
Specifies the number of frames to display.
- BYTE
AddH
- BYTE
AddM
- BYTE
AddL
- BYTE
G4D_SetVolumePicaso
Sets the playback volume.
- BYTE
Volume
Volume = 0 - Mute Enabled / 1 - Volume Down 8 / 3 - Volume Down 1 / 253 - Volume Up 1 / 254 - Volume Up 8 / 255 - Mute Disabled / 8 - Minimum Volume Level / 127 - Maximum Volume Level
- BYTE
SetDisplayOrientation
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
Window
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
G4D_DumpScreenToCard
Copies a section of the display to the micro SD card starting from X, Y and ranging to Width, Height. The address parameters assign where on the card to store the data.
- UINT
X
- UINT
Y
- UINT
Width
- UINT
Height
- BYTE
AddH
- BYTE
AddM
- BYTE
AddL
- BYTE
G4D_SetVGADisplaySizePicaso
Specifies the VGA display size in pixels. Size = 0 - 320 x 240 Resolution. Size = 1 - 640 x 480 Resolution. Size = 2 - 800 x 480 Resolution. Size = 3 - Custom Resolution
- BYTE
Size
- BYTE
ClearDisplay
SetBackgroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
G4D_DisplayImageFromCard
Attempts to print an image from the micro SD card at the specified address location on the card. The image is printed at location starting from X, Y and ranging to Width, Height.
- UINT
X
- UINT
Y
- UINT
Width
- UINT
Height
- BYTE
ColourMode
Specifies the colour depth setting - 0 = 8-bit colour, 1 = 16-bit colour.
- BYTE
AddH
- BYTE
AddM
- BYTE
AddL
- BYTE
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
G4D_SetTouchRegionPicaso
Specifies the area of the screen which will respond to touchscreen inputs.
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
G4D_PlayAudioFromFilePicaso
Attempts to stream an audio wav file from the micro SD card using the specified filename.
- BYTE
Play_Option
Play_Option = 0 - Return when playing complete / 1 - Return immediatley / 2 - Stop Playback / 3 - Pause Playback / 4 - Resume Playback / 5 - Loop Playing until stopped
- STRING
Filename
- BYTE
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Pixel Height
Pixel Width
Monochrome
Foreground Color
Background Colour
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Display Method
Console Columns
Data Source
TX
RX
Reset Pin
I/O pin connected to the reset signal on the gLCD
Baud Options
High Speed
Determines if the baud rate is automaticaly switched from 9600 baud on initialise to 57600 baud. Only available in hardware mode.
Simulations
