Component: RF 2.4GHz (nRF24L01) (Wireless)
Revision as of 11:10, 17 November 2021 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Wireless
RF 2.4GHz component
A simple RF communications module based on the 2.4GHz nRF24L01 modules.
Fc9-comp-macro.png ReadRxByte
Reads a single byte back from the local Rx buffer.
Fc9-u8-icon.png - BYTE Index
Byte to read, range 0 - 31
Fc9-comp-macro.png WriteTxByte
Reads a single byte to the local Tx buffer.
Fc9-u8-icon.png - BYTE Value
Fc9-comp-macro.png FlushRx
Tells the RF module to flush the contents of the receive buffer. Returns the status from sending the command.
Fc9-comp-macro.png ReadRxFifo
Reads the Rx FIFO buffer into a local buffer. Use the ReadBuffer macro to collect the individual data bytes.
Fc9-u8-icon.png - BYTE NumBytes
Number of bytes to try and read from the FIFO Range 1-32
Fc9-comp-macro.png WriteTxFifo
Writes the contents of the local Tx buffer to the Transmit FIFO.
Number of bytes to write to the FIFO, Range 1 - 32
Fc9-comp-macro.png FlushTx
Tells the RF module to flush the contents of the transmit buffer. Returns the status from sending the command.
Fc9-comp-macro.png CheckRX
Check the Rx FIFO status register for any new data. Returns 0 = No data Returns 1 = New data available
Fc9-comp-macro.png ReadRegister
Reads a single bytes from the selected register. Directly returns the value read back from the register.
Fc9-u8-icon.png - BYTE Reg
Register address to access
Fc9-comp-macro.png SetTxMode
Sets the module up ready to transmit data.
Fc9-u8-icon.png - BYTE PA0
Pipe Address Bytes
Fc9-u8-icon.png - BYTE PA1
Pipe Address Bytes
Fc9-u8-icon.png - BYTE PA2
Pipe Address Bytes
Fc9-u8-icon.png - BYTE PA3
Pipe Address Bytes
Fc9-u8-icon.png - BYTE PA4
Pipe Address Bytes
Fc9-comp-macro.png SetRxMode
Sets the module up ready to receive data.
Pipe Address Bytes
Pipe Address Bytes
Pipe Address Bytes
Pipe Address Bytes
Pipe Address Bytes
Fc9-comp-macro.png WriteRegister
Writes a single byte to the selected register. Returns the status of the write command.
Fc9-comp-macro.png Initialise
Starts up and configures the RF module ready for use. The macro will return a value greater then 0 if the module has been started correctly, otherwise the macro will return a 0.
Fc9-type-21-icon.png RF Channel
Sets the RF channel from 0 - 127 = 2.4000GHz - 2.525GHz Both the transmitter and receiver should be on the same channel to receive data.
Fc9-type-16-icon.png Channel
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-type-5-icon.png CE Pin
Chip enable, configures RX or TX mode
Fc9-conn-icon.png Simulations
Fc9-type-10-icon.png Label
Fc9-type-16-icon.png API
