Component: DAC Quad (MCP4728) (MCP4728) (Analog Output)
Version | 1.0 |
Category | Analog Output |
DAC Quad (MCP4728) component
Component to drive a quad digital to analogue converter (DAC) IC from Microchip via an I2C interface. Compatible with MCP4728 (12-Bit) devices.
SetOutput |
Sets the output voltage of the DAC 12-Bit: Range 0-4095 | |
Channel |
Range: 0-3 / 0=DAC Channel 0 / 1=DAC Channel 1 ... | |
DAC_Value |
The value to output to the DAC | |
Return |
ControlPins |
Allows Shutdown (SHDN) and Latch (LDAC) pins to be controlled directly if enabled. | |
[[File:]] - | Latch |
0 = Data output driven from DAC register, 1 = Data output locked | |
Return |
Disable |
Disables the DAC output. | |
Channel |
Return |
Enable |
Enables the DAC Output. | |
Channel |
Return |
Initialise |
Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated. | |
Return |
