Component: Filter (DSP)
Revision as of 13:27, 17 November 2021 by Wiki bot (talk | contribs)
Version 1.3
Category DSP
Filter component
Filter component to allow basic filtering to be performed Filters include: LowPass, HighPass, BandPass, BandStop, FIR, IIR
Low Pass Filter
Example of the filter component set up to create a low pass filter with the input frequency controlled using the potentiometer on the panel. FC6 Icon.png LowPassFilter Low pass filter running at a low frequency - note that the amplitude of the filtered data closely matches that of the original waveform data.
Low pass filter running at a high frequency - note that the amplitude of the filtered waveform is now greatly attenuated.
High Pass Filter
Example of the filter component set up to create a high pass filter with the input frequency controlled using the potentiometer on the panel. FC6 Icon.png HighPassFilter High pass filter running at a low frequency - note that the amplitude of the filtered waveform is greatly attenuated.
High pass filter running at a high frequency - note that the amplitude of the filtered data closely matches that of the original waveform data.
Band Pass Filter
Example of the filter component set up to create a band pass filter with the input frequency controlled using the potentiometer on the panel. FC6 Icon.png BandPassFilter Band pass filter running at a low frequency - note that the amplitude of the filtered waveform is greatly attenuated.
Band pass filter running at a mid frequency - note that the amplitude of the filtered data closely matches that of the original waveform data.
Band pass filter running at a high frequency - note that the amplitude of the filtered waveform is greatly attenuated.
Fc9-comp-macro.png Filter
Performs the filter operation to the current value in the buffer.
Fc9-comp-macro.png SetFilterCoefficient
Allows the coefficients of low pass, High pass, band pass and band stop filters to be edited. Must be enabled using the Variable Coefficients property.
Fc9-u8-icon.png - BYTE Index
Range: 0-1
Fc9-u16-icon.png - UINT Value
Fc9-comp-macro.png FilterArray
Performs the filter operation to the contents of the entire buffer in one go.
Fc9-type-17-icon.png Connect To
Fc9-type-16-icon.png Buffer Type
Sets the buffer data type.
Fc9-type-16-icon.png Type
Specifies the filter type created by the component: Low Pass - Filters out frequencies above the cutoff frequency High Pass - Filters out frequencies below the cutoff frequency Band Pass - Combination of High Pass and Low Pass Filters Band Stop - Inverse of Band Pass FIR - Finite impulse response using standard filter coefficients IIR - Infinite impulse response using standard filter coefficients
Fc9-type-7-icon.png Variable Coefficients
Decides if the coefficient values can be altered during runtime using the SetCoefficient component macro. Only available for the simple filter types, low pass, high pass, band pass and band stop.
Fc9-type-14-icon.png Coefficient 0
Cutoff frequency = Nyquist frequency / Coefficient Cutoff frequency is described as when the unwanted frequencies in the signal have been attenuated by at least 50%
Fc9-type-11-icon.png A Coefficients
Comma seperated float data containing filter coefficient values
Fc9-type-11-icon.png B Coefficients
Fc9-type-15-icon.png Sample Rate
Sample frequency used to work out some basic useful calculations
Fc9-type-15-icon.png Nyquist Frequency
Maximum theoretical frequency that can be obtained by the sample frequency
Fc9-type-15-icon.png Cutt Off Frequency 0
First cutoff frequency
Fc9-conn-icon.png Simulations
